Where can I find stock u-bolts for rearend shackle?
Discussion in 'Suspension' started by RaiderSix, May 18, 2007.
  1. May 18, 2007 at 5:35 PM
    RaiderSix
    RaiderSix [OP] Well-Known Member
    The previous owner of my truck put 2" lowering blocks in the rear and the associated way oversized u-bolts were used to bolt it up. I want to toss the lowering blocks and bring the original ride height back. I can't find regular sized u-bolts for the rearend/spring shackle at any of the auto joints. Know where I can get some...short of the boneyard?
  2. May 23, 2007 at 1:05 PM
    twoarezee
    twoarezee Well-Known Member
    esco, ca
    00 Dropped Mini
    rims,tires,3"/6" drop, 4x4 front end, 01 tails and corners, prerunner buckets,tenzo r steering wheel w/ momo hub, b&m shifterw/ jdm trd knob, alpine system, tint, 3 3/4" autometer tach, jardine cat back, k&n, debaged, hellwig rear sway bar, kyb monomax shocks, tundra v8 oil filter w/ mobil 1 in ever
    i got some at autozone and trimmed them down. i also have a set of oem ubolts if you want them.
  3. May 25, 2007 at 6:03 PM
    RaiderSix
    I found some that worked at Napa. I had to trim them down, but oh well.
