where do I measure from?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bartaco, Apr 29, 2011.
  1. Apr 29, 2011 at 8:53 PM
    Bartaco
    Bartaco [OP] Well-Known Member
    Bill
    Connecticut
    Red extra cab 6 cyl with chip,gibson flowma
    Bilstein 5100 series ,uniball uca's,3" lift kit ,extra leaf, Gibson exhaust.limited slip rear, six lug,lock out hubs,K&N air cleaner sysytem
    hey all where do I measure from to find out which lift kit the previous owner put in this truck? I know its got a kit in it but I want to know how high he went.
    Oh yeah and do alot of people go with uniball UCA's on these trucks? I have them and they work well ...just wondering how popular they are.
  2. Apr 29, 2011 at 9:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Most folks measure from the center of the axle, to the bottom of the fender.
  3. Apr 30, 2011 at 11:34 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    +1
    That is the correct way to measure. Many people measure from the top of the tire to the bottom of the fender which would work if you always stick with the same tire & wheel.
    Measuring from the center of the spindle/axle to the bottom of the fender will be accurate no matter what tire & wheel size you have or change to.
