Where is the in-cab Diagnostic Port???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slider57, Feb 16, 2014.
  1. Feb 16, 2014 at 1:45 PM
    Slider57
    Slider57 [OP] Active Member
    Bailey, CO
    14 ACSB 4WD SR5 V6
    I have a 2014 Taco Access Cab. I was in the process of installing a Scan Gauge, and as I'm ready to plug it in, I could not locate the Diagnostic Port under the dash. My '10 FJ had one under the driver's side footwell.
    Any ideas guys??? As always, thanks for the help...
    HellaDave likes this.
  2. Feb 16, 2014 at 1:51 PM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
  3. Feb 16, 2014 at 1:57 PM
    Slider57
    Bailey, CO
    14 ACSB 4WD SR5 V6
    jmg256, you are a LIFESAVER!!!! :bananadance::bananadance::bananadance:
    I never would have seen it.
  4. Feb 16, 2014 at 1:57 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
  5. Feb 16, 2014 at 2:13 PM
    GreatCanadian
    GreatCanadian Well-Known Member
    Newfoundland
    SR5 4X4 V6
    On the topic of the ultragauge/scangauge, my truck is a 2014 as well. It has the auto-dimming mirror with compass, but not the temp gauge. Do you know if it would be wired for temp gauge? Or will I have to add a sensor. My truck is SR5 Canadian issue. Thanks for your time.
  6. Feb 16, 2014 at 2:33 PM
    Slider57
    Bailey, CO
    14 ACSB 4WD SR5 V6
    My 14 Taco is not wired for the outside temp gauge, nor does it have the compass or auto dim. From what I've learned, none of the '14s have the temp feature anymore. Trolling this Forum, I found Gerry in Michigan that sells Gentex mirrors so we can add the temp feature to our 14's, but I'm not sure how you'd integrate it into your current mirror.
    Check this tread out for more info: http://www.tacomaworld.com/forum/2n...mp-sensor-install-2014-off-road-pictures.html
  7. Feb 16, 2014 at 3:51 PM
    jmg256
    Al Tonter
    TRD Offroad
    The scangauge/ultra gauge devices will give you the option of displaying intake air temperature. I find that the intake air temp is within ~1°-3° above ambient. Just another option for you. Of course, if you're sitting in traffic, idling, with the sun beating down...intake air temps will rise and readings will be skewed, but will return to ~ambient once you get moving again.
    Or you could do this...
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/307389-option-adding-temp.html
  8. Feb 16, 2014 at 4:21 PM
    GreatCanadian
    Newfoundland
    SR5 4X4 V6
    Thanks guys, I will read your links. My desire for external temp reading is due to where I live. I want to know when temps are approaching freezing. A lot of our late fall and early spring days temps are hanging around freezing, and I do like to know when I have to be a little aware of roads turning slippery. After driving in it for years you kinda get too used to it and it can catch you unawares.
