Where is the Trans fill plug for a 08 4X4 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DRTCWBY, Mar 26, 2011.
  1. Mar 26, 2011 at 4:38 PM
    DRTCWBY
    DRTCWBY [OP] Member
    Bend
    2011 DC LB 4X4
    I know where the 24mm fill plug for the AT on a 2wd rig but I can't find the fill plug on the 4x4 4.0 model. Does anybody have any pictures they can post or a treasure map to head me to that elusive "ws" plug.
    THANKS
    DC
  2. Mar 26, 2011 at 4:43 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
  3. Mar 26, 2011 at 5:15 PM
    DRTCWBY
    DRTCWBY [OP] Member
    Bend
    2011 DC LB 4X4
    I appreicate the post. I too found that when I searched the site for plug locale. #7 is for a manual trans. Looking for the drain plug on a Auto Trans with 4x4. Am I missing it?
    I saw in the DIY Trans flush sticky thread there is a picture of the fill plug but the tranny illustraded is 2wd AT. The 4wd Trans is fuller bodied at the tail to match up to the transfercase and the fill plug is not in the same locale as the 2wd.
    Anybody know where this bad boy is?
  4. Mar 27, 2011 at 2:51 AM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
  5. Mar 27, 2011 at 9:35 AM
    DRTCWBY
    DRTCWBY [OP] Member
    Bend
    2011 DC LB 4X4
    Quaker -
    I appreciate the post - the thread that you referred to is the one that I had seen before and mention in post #3. The link you gave me is for a 2wd transmission fluid change. The thread shows wherre the fill plug is on the 2wd but it doesn't illustrate where the plug is on a 4wd tranny. As I mentioned in post #3 the transmissions are different to accomodate the 4X4 transfercase. So with that said the fill plud is in a different locale on the 4x4 than on a 2wd.
    So thus the reason for my original question -
    Does anybody know where the fill plug is on a 08 4x4 4.0L Auto transmission?
    Thanks Again -
    DC
  6. Mar 27, 2011 at 10:12 AM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    Here is the PDF for fluid level adjustment. Shows location for fill and overflow plugs (to get the proper fluid level) Good luck!
  7. Mar 27, 2011 at 11:33 AM
    DRTCWBY
    DRTCWBY [OP] Member
    Bend
    2011 DC LB 4X4
    anethema - thats what I'm talking about!
    THANK YOU!
    DC
  8. Mar 27, 2011 at 11:42 AM
    DRTCWBY
    DRTCWBY [OP] Member
    Bend
    2011 DC LB 4X4
    Anethema - by the way where did that illustration come from? It's good stuff and would love to have that kind of info in the garage!
    Thanks again -
    DC
  9. Mar 27, 2011 at 11:44 AM
    anethema
    J
    Dawson Creek,BC
    Full service manuals for all tacomas basically.
    I don't imagine they are allowed to distribute that so I made a local copy. I suggest you do the same.
    Enjoy!
  10. Mar 27, 2011 at 11:53 AM
    2011tacoma4x4
    2011tacoma4x4 Active Member
    Antonio
    Arlington, TX
    v6 4x4
    TRD supercharge, TRD cold air intake,tail gate mode, HID 6000k headlight/foglight
    it the same on drain plug, but you need a pump to fill in the fluid, when it full fluid will come back out, when you drain the trans measure how much fluid come out, and refill just a little above the amount that come out.
  11. Jan 20, 2013 at 3:56 PM
    xpert1111
    xpert1111 Well-Known Member
    Central NJ
    2018 DCLB Sport
    anyone know why the above link does not work? thanks
  12. Jan 20, 2013 at 4:02 PM
    DR Da_da
    DR Da_da Infrequent Member
    Alabama
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    I heard Toyota made them take down the factory manuals.
  13. Jan 20, 2013 at 4:05 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Bottom of the pan..so fun.
    Make sure to catch and measure everything you take out. And out in the same amount. Boom done.
  14. Feb 14, 2015 at 5:32 PM
    CalHigh
    CalHigh New Member
    Does anybody have picture they can help with? I have the 4x4 as well and its different from the 2wd. I cant seem to find where the fill plug is. Ive read through the 23 pages on the earlier thread that was mentioned but didn't see anyone mention the 4wd. Iknow its an old thread but the search function didn't help me much and I didn't really see a need to create a new thread
