Where is the VSS located?
Discussion in '1st Gen. Tacomas (1995-2004)' started by wolfgang123, Jun 11, 2013.
  1. Feb 16, 2023 at 11:56 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    For the OP, who no longer needs this information:
    1995-1997 have mechanical speedometers, the VSS is in the speedometer.
    For the thread revivist:
    1998-2023 have electronic speedometers, with the VSS signal coming from various sources, depending on year and options. For your 2005, the speed signal is calculated by the ABS ECU, which is output to the gauge cluster, where it is then output to the rest of the systems in the truck. It's not a single sensor, it is based on more than one sensor.
    Jeff
    DrabT100 and Fantastic11 like this.
