Where should I get parts? Switch to synthetic?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Raven Creek, Mar 3, 2010.
  1. Mar 3, 2010 at 5:13 PM
    Raven Creek
    Raven Creek [OP] New Member
    Iowa
    98 Tacoma SR5 TRD
    I have recently purchased my first Toyota. It is a 1998 Tacoma SR5 TRD XTra cab, 3.4L V6, 5 speed with 140K. It is rust free and in very good shape for age and miles. I am going to do a timing belt/water pump, tuneup, and fluid change on it. I was wondering if I should get parts from Toyota or from a reputable parts store(Arnold's or NAPA). And should I change all of the fluids over to synthetic. I am a certified ex-GM mechanic, but my Toyota experience is limited. Any input will be helpful.
    Thanks
    RC
  2. Mar 3, 2010 at 5:18 PM
    bigyetti
    bigyetti Well-Known Member
    mike
    asheville, nc
    08 taco dc 4x4 short bed
    sirius satilite radio, more on the way when i get more money. oh ya removed the secondary filter
    welcome to TW. Just a moment and the pros will answer all your ?. enjoy
  3. Mar 3, 2010 at 5:50 PM
    Idrivetoys
    Idrivetoys Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    Check prices on the parts first off, dont buy the cheapest but its not necasary to buy from Toyota unless you want to, I personally like to buy certain things from them, clutches being the primary. As for your belt and water pump a replacement from Advance/Auto zone is perfectly fine as well as the spark plug wires, the spark plugs on the other hand Toyota recommends dual tipped plugs, so either buy from toyota or make sure you get something with a dual tip. Ie bosh +2 or V powers etc.
    Fluids: Again toyota puts out great products, however i always change to at least a syntec blend if not fully synthetic, one of the greatest things about synthetic is that it is not affected as much with temp changes, therefore you get a more consistent range of protection. Its not necasary to change ALL fluids but a oil, coolant (your doing the water pump anyway) are essential so you know where you stand and at least check the levels on the trans and rear diff, and if your feeling like it change them anyway.
    As you can see a lot of this falls under preference and many people will chime in on what they would do. I say play it safe with a used vehicle, change all the fluids go with syntec or a blend and enjoy the truck as long as possible
  4. Mar 3, 2010 at 6:00 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    within the first month of buying my 05 with 70k i changed out front and rear diffs with royal purple... also did the transfer case. and im gonna take it in to the stealership for a tranny flush this weekend!
  5. Mar 3, 2010 at 10:24 PM
    pdxwhiteout
    pdxwhiteout monster taco in the snow
    coty
    pdx
    monster tacoma
    3-inch body lift, 6-inch fabtech lift, 17-inch procomp black alloys wrapped in bfg 37s. trd v-6.
    i would recommend buying from toyota. its going to be a little more $ but from one tech to another former tech, my exp is with honda and lexus(toyota), i replace aftermarket t-belts all the time for concerns ranging from noise to premature wear. and as you know very well know a t-belt is a cheap part compared to buying valves or even a motor because of a t-belt failure. good luck, welcome to TW!
  6. Mar 3, 2010 at 10:27 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    The 3.4 is a non-interference motor meaning the valves cant hit the pistons in the event of a t belt breakage.
    I just got a gates belt from NAPA and whatever brand water pump they had there. so far no probs.
  7. Mar 4, 2010 at 11:52 AM
    Raven Creek
    Iowa
    98 Tacoma SR5 TRD
    Thanks for the input. Keep it coming.
