Where to buy a new transmission
Discussion in 'Texas' started by ddavis8, Jul 20, 2020.
  1. Jul 20, 2020 at 6:36 PM
    ddavis8
    ddavis8 [OP] Member
    Dan
    2013 Dubcab MT 4x4
    Bumper, steps, lights
    Looking to replace the transmission in my 2013 4wd. Where would you guys buy it from? I priced it at Toyota of Dallas/TRD parts for ~3250 plus it's going to probably be a couple hundred freight to Corpus. Should I look anywhere else? I've never bought anything this big from Toyota before. I'll be replacing the clutch too. The performance of the stock clutch is fine, but the throw out bearing situation isn't. Is a Toyota OEM clutch with the URD throw out bearing fix the best thing going?
    Thanks,
    Dan
  2. Jul 21, 2020 at 2:36 PM
    nuvoturbo
    nuvoturbo Well-Known Member
    Sam
    2014 Super White Tacoma TRD T/X Baja
    Why not get the original transmission rebuilt? If its a manual, it should be fairly inexpensive.
    Yota4Life89 likes this.
  3. Jul 21, 2020 at 3:05 PM
    ddavis8
    ddavis8 [OP] Member
    Dan
    2013 Dubcab MT 4x4
    The rebuild kit is $900. I asked about cost if I was to bring the transmission in and was quoted $1600, which seems reasonable considering the ridiculous $900 for the kit. I figure it would be about $2k if I bring the truck in. If I get a new transmission I can swap it myself and possibly get one that doesn't have an obnoxious gear whine at highway speed. I don't know if the RA60s are all this way or if it's the tolerances of this particular one. My 2004 is quiet in comparison.
  4. Jul 21, 2020 at 3:06 PM
    ddavis8
    ddavis8 [OP] Member
    Dan
    2013 Dubcab MT 4x4
    FWIW the dealer says the transmission needs to be replaced and wants about $6k, lol.
  5. Jul 21, 2020 at 7:21 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Imo I’d rebuild it. But more importantly the transmission should have lasted longer than 7yrs unless your a gear grinder.
  6. Jul 21, 2020 at 8:29 PM
    tony2018
    tony2018 Well-Known Member
    labor...
  7. Jul 21, 2020 at 8:34 PM
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
  8. Jul 21, 2020 at 8:41 PM
    ddavis8
    ddavis8 [OP] Member
    Dan
    2013 Dubcab MT 4x4
    I still have my 2004 with 280k miles and I didn't replace the factory clutch until 270k. I bought this truck from an individual at 89k. The problem doesn't show up until the transmission has warmed up for 10-15 minutes, which would explain why we did the test drive a few blocks from his house. Now it's my problem. No idea how he killed the transmission. Probably letting his kid learn on it and it's a shit transmission with known weak synchros. Either way, has to be fixed.
    gotoman1969[QUOTED] likes this.
  9. Jul 22, 2020 at 12:20 PM
    nuvoturbo
    Sam
    I would check your local salvage yards and see if you can find a transmission out of a wrecked Tacoma. There are also companies that specialize in JDM imports. They typically offer a 6 month warranty Might find a good used one from one of those.
  10. Aug 7, 2020 at 8:23 AM
    tony2018
    I believe that would be the cause.
