Where to buy single 12" sub box for 05+ double cab
Discussion in 'Audio & Video' started by OoRrLlYy, Jun 13, 2012.
  1. Jun 13, 2012 at 1:04 AM
    OoRrLlYy
    OoRrLlYy [OP] Member
    Kalihi/Oahu/Hawaii
    '12 TRD sport DCLB 4x4
    Yes I've searched! Only came up with 10" options. Mounting depth of the sub I'm installing is 3.5" and need 0.6cu ft of air space. Also, if possible, I dont want to cut anything. Just point me to the right direction please and thank you!! :)
  2. Jun 13, 2012 at 2:48 AM
    CantSitStill
    CantSitStill Well-Known Member
    FTR
    CNY
    Subbed for the sub!
  3. Jun 13, 2012 at 2:53 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    idk of a single. maybe custom?
    i’m going to do 2 shallow mount 12”s and new head unit all at same time.
  4. Jun 13, 2012 at 3:21 AM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    3.5" mounting depth + 1/2" mdf for back of box and another 1/2" for front of box + 1/2" for the rim of the sub, and at least 1/2" extra for proper excursion room =
    5.5" of total depth.
    I have the JL stealth box which is loaded with 2 JL 10w1v2 which require a 4.3" mounting depth. Add the side of the box like I did with yours and you get about 6" of total depth. My box fits very snug behind my back seat and is mashed up against the cab wall.
    Basically what I'm saying is that you should be able to get it behind the back seat, but when accounting for the larger diameter of the sub its going to be a tight fit. I highly recommend going to a reputable shop and negotiating a price for a custom Fab box. Trust me when I say this, you WILL NOT regret it ** ONLY if your tech knows what he's doing and can accurately calculate cubic airspace and port dimensions when designing the box!!!** If you find the right guy, it will be worth every penny. I would estimate $150 in parts and labor for a single 12" custom ported enclosure. But a good shop may be slightly higher.
    Take your time, shop around, you will know when you find the right person.
    EDIT: I may be able to have one made and shipped but I will need specifications of your sub. Price will obviously be higher for shipping, but should be worth it if you really want to do it right. No hard feelings if your in budget mode though, I think most of us out there are :(
  5. Jun 13, 2012 at 6:39 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    When you say you don't want to cut, are you referring to the truck, the box, or both? With the depth and airspace requirements you've given, one of the 10" boxes should work if you're willing to cut the box, or take it to someone who can cut the 10" hole to 12".
  6. Jun 13, 2012 at 9:53 AM
    hotrodbanshee
    hotrodbanshee Well-Known Member
    Clayton
    El Campo,Tx
    2012 TRD Sport 4X4 Double Cab
    What sub are you looking at using?
  7. Jun 13, 2012 at 11:27 AM
    OoRrLlYy
    Kalihi/Oahu/Hawaii
    Thanks for the info bro. I think It's kinda leaning more on the custom box size now that I keep reading about it. But yah to have you make a box and ship it out to Hawaii will probably be high price wise.
    I want to stay away from cutting anything (box and truck) if possible.
    I was looking at Alpine's thin line Type-R....swr-t12
  8. Jun 13, 2012 at 12:26 PM
    hotrodbanshee
    Clayton
    El Campo,Tx
    Ya I was looking at the type r swallow or the polk mm1240 12"sub for my wifes double cab.
  9. Jun 13, 2012 at 3:08 PM
    ProForce
    Anthony
    Alaska
    +1
    This is actually a great idea. If you find a 10" box with the same mounting depth requirement and enough front surface area you could easily turn it into a 12" enclosure without compromising it at all. It would be your best and cheapest option I think.
  10. Jun 20, 2012 at 5:10 PM
    j753301
    j753301 Active Member
    South Hadley , Mass
    2010 Toyota Tacoma TRD Sport double cab
    I just picked up a Rockford punch p3 shallow mount 12" single sub box and it fits perfect behind the seat with the plastic taken out and sounds amazing!!
  11. Jun 20, 2012 at 5:16 PM
    Taqoma
    Taqoma Well-Known Member
    Brennan
    Los Angeles
    2011 TRD Off-Road
    TRD Supercharger, TRD CAI, Camburg LT, Fox 2.5x8 coilovers, Fox 2.0 bumps, Deaver e30 leafs, Fox 3.0x18 triples, Avid sliders, Yaesu 2900R, Pro Comp 7089 16x8, DDM 55w HID Hella 500FF, DDM 35w HID headlights, Magnaflow 11255 muffler, PLX DM-100 OBDII, Autometer Ultra-Lite II Boost gauge, Flex Pod gauge mount, LSK tube bumper, McNeil fenders, Fiberwerx bedsides, 285/75/16 Toyo MT's
  12. Jun 21, 2012 at 11:45 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
