Where to get a Skid Controller ECU? 2K 3.4L TRD Off Road.
Discussion in '1st Gen. Tacomas (1995-2004)' started by itr1275, Jul 27, 2020.
  1. Jul 27, 2020 at 10:39 PM
    itr1275
    itr1275 [OP] Well-Known Member
    Jerold
    San Jose CA
    '00 Tacoma TRD Off Road
    Icon Coilovers, Daystar Shackles. Sliders.
    This is 2K Tacoma 3.4L Extra Cab TRD Off Road 4WD.
    Ok it's time to see if I can fix the Taco. . . Maybe.
    I've searched a bunch in this and other forums. Will check the brake fluid, clean all the gunk, check the connectors, fuse etc...
    The symptom is I barely touched the brakes and the ABS kicked in. This happened a few times over a week and the ABS light has been on ever since. I also need to replace the 1/2 shafts which have the reluctor on there. So it's possibly related.
    The dealer said I needed a skid controller ECU (ABS computer). They wanted like $2500 to fix it and I declined their offer. I suspected they went with that because every code says something "or ECU". This was diagnosed a few years back and no details other than it's broken. It's a weekend truck and I don't care much about ABS, but I don't like lights on either. So now I'm seeing if there is a cheaper way to fix it.
    Remember this is a 2000 and OBD II isn't really what it is today. I've seen a bunch of videos that tell me how to jump the connector and count the flashes to get the code. No problem I can do that, I'm not sure the Toyota Tech did that.
    It's entirely possible the ECU connector or ABS wheel sensors connectors have corrosion. Or a wheel sensor is shot. That stuff should be pretty simple to diagnose and fix. I can do that.
    On the chance that the dealer is correct, where do I even get the skid controller? I've checked Olathe Toyota, Bam Wholesale, Toyota Parts Deal. The part number is 44050-04010 and it seems to be discontinued.
    There are some in wrecking yards (https://www.car-part.com) and even someone eBay that says they will rebuild mine (https://www.ebay.com/itm/REPAIR-KIT...rol-Module-1997-2002-WE-INSTALL-/233182695041)
    Thoughts on the wrecking yard parts or the "repair kit"?
  2. Jan 2, 2021 at 11:40 AM
    ToyoTaco-02
    ToyoTaco-02 Member
    02 Tacoma Limited TRD
    I have been looking for one for myself on EBay. I saw one on EBay couple of weeks ago but the seller was asking more than $1K, too much for a used ECU. The ABS ECU’s for our trucks are hard to find. The wrecking yard I tried are PYP here in LA but no luck. Unfortunately, our trucks don’t make it to wrecking yards. I’ve been thinking about get it repaired here in LA by a local shop for $150, but I still have some more troubleshooting to do. Did you fix yours? thank you.
  3. Jan 2, 2021 at 1:31 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    The OBDII came into effect in 1996 no counting of flashes in your system
    Since I deleted the ABS system I can`t say if the lower end devices can read ABS codes
    About the only thing that can cause damage is getting water inside or a massive voltage spike.
    Gotta be someone who can rebuild them I have had a few ECM`s rebuilt I would need to look to find the vendor
    Maybe time to do away with the ABS brakes .
    Best of Luck
  4. Jan 2, 2021 at 1:53 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    OP posted awhile back
    It's the second guy that brought up the thread.
    Wyoming09[QUOTED] likes this.
