where to get quality stereo installation s calif?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xxxbigjohnxxx, Jun 13, 2010.
  1. Jun 13, 2010 at 11:24 AM
    xxxbigjohnxxx
    xxxbigjohnxxx [OP] New Member
    john
    california
    2010 access 4 cyl
    ventura county anyone know of a reputable installer?
  2. Jun 13, 2010 at 11:26 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    it's really not that hard to install yourself..
  3. Jun 13, 2010 at 11:28 AM
    lookylookitzadam
    lookylookitzadam Retrofit Club!
    Adam
    San Diego
    07 DC OffRoad
    get the conversion harness for wiring then its just match wire colors and plug it in. Install takes 20 minutes. Do it! =)
  4. Jun 14, 2010 at 8:49 PM
    xxxbigjohnxxx
    john
    california
    2010 access 4 cyl
    i only have the use of 1 arm
  5. Jun 14, 2010 at 9:18 PM
    lookylookitzadam
    Adam
    San Diego
    07 DC OffRoad
    gotcha, if you were down south I could possibly help, but I am not sure of anyone in ventura.
    Best of Luck
  6. Jun 14, 2010 at 9:57 PM
    bmgreene
    bmgreene Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    I had a system installed on my old 1st-gen by Al & Eds and was pretty happy with it (they put in a new HU, amp and sub since I had already swapped out the speakers myself before that), also had a good install done by Best Buy to replace a system that got ripped out of the same truck when I was living in Seattle.
    The Al&Ed's job was 12 years ago and the BB was 9 years ago, so things might have changed since then, and may be variable from store to store.
  7. Jun 14, 2010 at 10:55 PM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    all car stereo places are con artists .
    they cut corners and hide stuff most people will never see or notice.
    al & eds will cost you more $$ and youll get the same crap as
    Joe Bloughs jihad stereo center.
    the install is not real hard, but maybe help them out by ordering speaker adapters and stuff before you go into a shop. of course they will say they can do it, but you'll probably end up with speakers jammed into your doors not even covering the whole hole(and rattling) and they use drywall screws.!!!
    I have used www.crutchfield.com to order a few systems and their prices are real close or the lowest and they have real good instructions.
    check out www.tacotunes.com for adapters and check the audio section here for even more info. dont forget the dynamat :D(soundproofing)
    im sure you can find a friend or family member to help out on the install.
    if you were closer to LB I could help out.
    good luck.
  8. Jun 17, 2010 at 4:23 PM
    LBtaco
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    oh heres a little fun I got into today.
    I already put the dynamat on my rear doors and saw the horrible work a stereo shop did, had to make speaker adapters (like the tacotunes.com ones) all fixed no rattles and decent sounding bass.
    so today I crack into the front doors.. omg what a mess :confused:
    there is this thin piece of masonite holding my speakers in and that is sheet metal screwed into the door. the weather guard (plastic) is all over the place too.:( So, poiking around I find broken glass in my door, musta had a breakin before I bought it,:mad:
    anyways 4 hours later its all fixed and sounds much better. I didn't go all nuts with the dynamat just enough to take out the tinny sound. Heres some pics.
    and thats why you should do it yourself:taco:
  9. Jun 17, 2010 at 4:29 PM
    zanodave
    zanodave Well-Known Member
    so il
    07speedwayblue
    Just find a buddy to help you out. Then you will know what was done
