Where to get stock leaf spring u bolts
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rich48, May 15, 2018.
  1. May 15, 2018 at 10:52 AM
    Rich48
    Rich48 [OP] Member
    Rich
    97 Tacoma 4x4 5sp 2.7L
    Talking to a guy who also has a 97 extra cab and he is having trouble finding u bolts for his leaf springs. Said dealer wanted him to bring it in and have them do the work. All help? Is there an online source for stock parts, hopefully at a discount
  2. May 15, 2018 at 10:54 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Have him bring the old ones in to someplace that custom bends them; when I redid the spring perches on my '84 Dodge it cost me $50 for the full set.
    E30325 likes this.
  3. May 15, 2018 at 11:15 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
  4. May 15, 2018 at 2:49 PM
    E30325
    E30325 Well-Known Member
    Nick
    2000 Tacoma TRD 5spd
    5100's and OME 881's, AAL and KM3's
    Same here, $50 locally
  5. May 16, 2018 at 12:22 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Most any Spring Shop unless they are Dickheads has them on the shelf or can make them .
    $50.00 for a set (4) sounds expensive but it is a local market type of thing
  6. May 16, 2018 at 4:03 AM
    johnny3
    johnny3 Well-Known Member
    01 Tacoma TRD
    Kanas City Spring Co. google it
  7. May 16, 2018 at 8:53 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
  8. May 16, 2018 at 9:22 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Yup, OMEU53 are the u-bolts used for just about every Toyota, good quality. Those fit my 1991, they fit my 2008.
    There are 3 options with the difference being how long they are.
    U53 168mm (6.6")
    U53A 185mm (7.2")
    U53B 200mm (7.9")
    They are all 75mm center-to-center of the rods and 14mm (about 9/16") diameter rod. The inside dimension of u-bolts for our trucks should be about 2.5" inside between the legs to match the leaf width and you should use at least 1/2" diameter rod.
    For stock leafs you only need the ~6.5" long u-bolts but the longer ones are need with thicker packs. I used U53A with my Dakar CS047R packs and they didn't need to be trimmed.
    I've also used Rancho u-bolts in the past and they worked fine. It ain't rocket surgery, get a good brand or have them made locally at a spring shop.
  9. May 16, 2018 at 10:07 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Keep in mind the price for the lowrange offroad U bolts are for an individual U bolt. So 4 of those plus shipping brings you basically to the cost of having a local shop make them for you (~$50 mentioned earlier).
    That said, I'd probably still be able to order them and do it myself in the time it would take to find a reputable shop nearby and have them make you some.
    If they are too long, just cut off the excess...
    DaveInDenver likes this.
  10. May 16, 2018 at 10:10 AM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    Exactly. Just watch that you don't get them way too long and run out of thread. If you think you'll need about 6.5" but aren't sure get the 7" or 7.5" but not the 12" long ones.
