Where to place jack and jack stands under truck?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Veccster, Apr 12, 2010.
  1. Apr 12, 2010 at 9:33 PM
    Dmonkey
    Dmonkey Well-Known Member
    Branden
    NorCal
    VZN159L (2002 DC)
    Eibach height adjust shocks in front, KYB monomax shocks in the back. Stock springs front and back. Level 8 MK6 10mm offset wheels on Cooper ATP tires (stock size)
    These are the rules I live by:
    if you jack a car up and the body starts crunching, if its yours, set it down and find a better location, hammer down the bent floor panel. if its not your car, who cares?
    when jacking a rear while drive up from the front, always make sure you're on an incline and select neutral and chalk the front tires, proceed to lift the front of the truck, lifting the back, chalk the rear tires then lift.
  2. Apr 13, 2010 at 6:39 AM
    Mandy3206
    Mandy3206 Well-Known Member
    San Juan PR
    Sand Pearl Black 06 6spd DC SB TRD OR Moded
    Irresponsible attitude, if you don't know where to lift a vehicle don't do it, it's dangerous if you do it wrong, not to mention unnecessary damage to the vehicle.
    NEVER JACK OR LIFT A VEHICLE IN AN INCLINE, IT'S PLAIN STUPID AND DANGEROUS TO DO SO. MANY PEOPLE HAVE BEEN KILLED DOING SO.
    Always use the frame to lift the vehicle from the sides, the pumpkin in the back or SASed fronts. For IFS 05+ Tacos, there is a dome welded to the front cross-member in front of the oil plug, that is the equivalent to the pumpkin in the back.
    Be safe, not stupid while lifting a vehicle if you don't have a big enough jack then go and buy one that fill the need and you can never have too many stands and wheel chocks in your garage.
    Using the right equipment for the job makes the job safer, easier and faster.
    I got an aluminum jack for $150.00 at costco, high jack stands for $27.00/set of 2 at kmart and chocks for $6.00/set of 2 at wallymart
    Not a big investment IMO, how much would it cost to fix your arm or leg if crunched by your truck? Not to mention the funeral costs..............
    specter208 likes this.
  3. Apr 13, 2010 at 6:58 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Feeding a troll just makes him stronger.
    Dmonkey, well done. :p
  4. Apr 13, 2010 at 9:52 AM
    Veccster
    Veccster [OP] bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    Don't worry...I'm listening :eek:
    I've never jacked up a vehicle to rotate tires. I knew I was not doing it the best or safest way but I was careful to not put myself in a situation that would cause injury. Truck components can be fixed - amputated body parts cannot (most of the time).
    Anyway, that is the reason for this post. I'm sure most of you know enough about vehicles or had someone at some point in your life show you how to do it. Others, like myself, have the balls to try and figure it out on our own. If we screw up, we deal with it. Eventually, I'll be on here telling some mechanically disabled kid how to jack up his truck. Remember....we all started somewhere.
    I appreciate anyone's and everyone's advice (and pictures).
  5. Apr 13, 2010 at 10:09 AM
    Veccster
    Eric
    2020 Pro
    Janster, this makes the most sense to me. Jack up the rear using the pumpkin and put jackstands in the same location I did in those pictures. That is easy enough.
    But where do you jack the individual sides from up front? If I wanted to lift both tires at the same time, I would use the crossmember like mjp did:
    But how do you lift the individual sides? I suppose the frame, right?
  6. Apr 13, 2010 at 11:35 AM
    Dmonkey
    Branden
    NorCal
    VZN159L (2002 DC)
    Sir, I've been lifting vehicles like I stated my whole life and its always worked perfectly! how can you say I'm not doing it right?
  7. Apr 13, 2010 at 11:51 AM
    Veccster
    Eric
    2020 Pro
    Yeah...I thought you were joking too. I'm obviously not here to tell anyone the right way to do it but I thought you were being a sarcastic troll.
    I also don't ever want you jacking up my truck! Crunching is bad :cool:
  8. Apr 13, 2010 at 11:53 AM
    Dmonkey
    Branden
    NorCal
    VZN159L (2002 DC)
    Lol, you sure you want to switch your answer from trolling to not trolling?
    is that the smart thing to do?
  9. Apr 13, 2010 at 11:54 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Um, they Toyota FSM manual clearly states the jacking points are on the front cross-member and the rear diff. The jack stand points are along the frame in certain locations and on the rear axle covering.
    Dmonkey- Jacking on an incline is extremely dangerous as it throws the center of gravity off. That said I've done it, but I've taken extra precautions with wheel chocks and the lifting point is at the high point of the incline only... even then I'm still weary about it. However, the Tacoma I can have the back on the lower part of my driveway a bit as there is a pretty mean front rake with the TSB AAL. Jacking up until the body panels crush in... Jesus you will never touch any of my vehicles.
  10. Apr 13, 2010 at 12:04 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Look at this pdf. This is out of the Toyota Service manual. Scroll down, there's a diagram that'll show you exactly where to jack from on each side.
  11. Apr 13, 2010 at 12:07 PM
    Janster
    Jandy
    Lancaster, PA
    I just hope and pray you never have any incidents that'll hurt you or someone else.
    Jtm3793 likes this.
  12. Apr 13, 2010 at 12:17 PM
    Tillers_Rule
    Tillers_Rule ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    I usually just hold the vehicle up with one hand and change the tire with the other hand. Hard to do when drunk but still manageable.
  13. Apr 13, 2010 at 1:22 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    jacking up a truck is simple. try a modern car. ones designed specifically for the stock jack. tabs in the body panel. most times, the jacking point is the exact same location that the jack stands need to be in. sucks.
    truck = cake. rear diff, tit shaped thing on front cross member. if i only need one corner. frame near targeted corner.
  14. Apr 13, 2010 at 1:29 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    x2
    Simple. :)
  15. Apr 13, 2010 at 2:00 PM
    #35
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Why not just buy a two post hydraulic lift? might cost a small amount more but...seems like an easier solution :D
  16. Apr 13, 2010 at 2:24 PM
    #36
    Veccster
    Eric
    2020 Pro
    I find it interesting that it's odd to you. Not all of us grew up in settings where we were taught or could learn this kind of stuff. My father has never changed his own oil and couldn't even begin to tell you where an oil pan is. Instead, he taught me how to run my own company and pay to have services like that done for me.
    But I'm a do'er and figured it out on my own. I now change the oil for both of my vehicles.
    And I do recognize that the frame is the best place to jack up a vehicle. Unfortunately, my jack does not extend enough to fully droop the suspension - I tried that first. Thus my quest began to find a better spot to lift from. I asked a neighbor and he simply said "just jack up the suspension". I suppose a block of wood in there would've done the job but I didn't think adding spacers that can break was a good idea.
    I suppose I need new jack stands too - or maybe cinder blocks to raise them up enough to support the truck AND droop the suspension.
    I'm simply asking for the safest and most logical spot to lift from. Doesn't seem that dumb of a question to me. And I'm sure many others are quietly lurking for the same information.
    Leepullin77 likes this.
  17. Apr 13, 2010 at 2:30 PM
    #37
    Caddmannq
    Caddmannq MotoNerd
    California
    2012 PreRunner TRD Sport DC LB
    Undercover toneau
    I've got a Camry & Bonneville, and I've used my atv jack on both, as it distributes the load better than a regular floor jack. I will usually put a 2x4 on the body seam which distributes the load further. This allows me to jack the front up just to the rear of the notch in the body seam where the jack is supposed to go.
    But my daughter has a Magnum with these plastic rocker covers, and the cutout in them is just big enough for the factory jack.. What a PITA to work on.
  18. Apr 13, 2010 at 2:36 PM
    #38
    Caddmannq
    Caddmannq MotoNerd
    California
    Undercover toneau
    Dude! Do NOT use cinder blocks! They are brittle and will shatter.
    Use short pieces of big lumber like a 4x6 or 6x6. You can nail pieces of 2x6 together to make up thicker pieces as well.
    Of course steel is even better (far better) but wood will "give" and distribute sharp loads where a cinder block can just go "snap!"
  19. Apr 13, 2010 at 2:39 PM
    #39
    Dmonkey
    Branden
    NorCal
    VZN159L (2002 DC)
    drive out to a field, and hold the brakes and dig the back end down to the diff so the wheels spin freely, swap back tires.
    drive forward over a rock so the front end is hanging in the air, swap front tires.
    done and done, no tools needed
  20. Apr 13, 2010 at 2:45 PM
    #40
    mjp2
    NJ
    You're a man who finds solutions. I like that about you. :thumbsup:
