Where to place jack and jack stands under truck?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Veccster, Apr 12, 2010.
  1. Jul 16, 2010 at 9:45 AM
    #81
    Cappy Cap
    Cappy Cap Well-Known Member
    Boston
    08 Reg. Cab
    K & N Intake, Alpine S-10 Shallow Mount Sub, Alpine CDA-9884 H/U, Alpine Type-R Components, Alpine Amp, 3.73 rear end, Welded on Muffler, Bug Deflector, Rain Guards, LCE Short Shifter,
    Ok, good call, this helps alot.
    Thanks again chris.
    rep for you for helping me out
  2. Feb 2, 2012 at 3:58 AM
    #82
    arvizu9618
    arvizu9618 Well-Known Member
    RT
    PHX AZ
    06 D-Cab SPORT SB
    Map/Dome Light on same time, Beep onLock, Anytime DTRL's, Fog Light on any time, Cockpit lights in footwells, night light in cup holder and rear of console, Radio ON w/ ignition off (off with timer), 3157 socket for rear turn signals (BRIGHTER), Reverse Light Mod, Tap light in console and engine bay, removed screen prior to MAP sensor, Blacked out lower valance, badges, center caps and door handles, Added door sill plates, JVC-KDHDR50 Head unit (HD Baby), Tinted exterior lights, Borla Exhaust.
  3. Feb 2, 2012 at 4:24 AM
    #83
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    ...I've always rotated my tires by putting the rear tires straight to the front and cris crossing the fronts to the rear. Am I doing it wrong this whole time??
    Holy thread bump! Pictures of bent cross member?? I jack it up in the front like mjp2 does also for tire rotations..
  4. Feb 2, 2012 at 4:39 AM
    #84
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    X2......that's DANGEROUS
    I throw a jack in the middle of my ATO IFS skid and under the pumpkin for the rear. :D
  5. Feb 2, 2012 at 4:50 AM
    #85
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    ditto...on the necro thread :D
  6. Feb 2, 2012 at 9:05 AM
    #86
    XXXX
    sKiP
    05 Prius
    I like them old and dead :eek:
  7. Feb 2, 2012 at 5:24 PM
    #87
    JoeTacoma02
    Can't blame the guy for using the 'search' function :)
    EDIT Mis-read it...never mind..
  8. Dec 3, 2013 at 6:17 AM
    #88
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Damn... How did you come across this thread almost 2 years after the last post? I assume you were searching for something but what led you here?
  9. Dec 3, 2013 at 7:18 AM
    #89
    RearViewMirror
    Craig Christ
    Lol... I understand that!
  10. Feb 23, 2014 at 9:41 AM
    #90
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Found this wondering if I could jack up the truck by the rear pumpkin. Seems I can. I was told that's not good for some vehicles.
  11. Feb 23, 2014 at 10:01 AM
    #91
    fenderpicks
    fenderpicks Well-Known Member
    Sooooo... From 6 pages of this, I still don't see an answer of where to place the jack and the stands lol. PDF links are all broken in previous posts.
    I usually lift the front end by this circle thing that sticks out..... It is right in the center.
    Never really out it on stands so..... Can't comment on that
  12. Feb 23, 2014 at 10:08 AM
    #92
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  13. Apr 24, 2016 at 6:58 PM
    #93
    MateoTorgy
    MateoTorgy Well-Known Member
    Mateo
    Minnesota
    2014 TRD OR AC 6 Cyl
    And Chris comes through for me again.
    chris4x4[QUOTED] likes this.
  14. Feb 27, 2017 at 1:14 PM
    #94
    Bosshoag
    Bosshoag Well-Known Member
    Mr. Doogan
    Virginia Beach, VA
    '20 4X4 TRD Off Road MT
    I'm here for knowledge folks, please feel free to inform me. Expedition Essentials Track Mount Weather Tech floor liners and window vents K&N air filter Summit Dakars in Matte Bronze -25 offset King suspension from Filthy Motorsports MESO customs white/red interior lights and MESO customs gasshole
    Love the old thread. This was helpful for me. I searched with Google. I only have two jack stands and one floor jack. I plan to use the stands on the rear and old the front up by the cross member up front with the jack but that seems a little sketchy, not having jack stands for the front too...
  15. Feb 27, 2017 at 7:45 PM
    #95
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    Here's an idea, use the spare. I know it's more work but look at it this way, you get to exercise the lifting and lowering mechanism and you can easily check the air in the spare. Then when you're on that lonely road on a rainy night and you get that flat you know the spare will come down and it will have air in it. Now doing your rotation you only have one tire off the ground at a time.
    Lineback likes this.
  16. Feb 27, 2017 at 7:51 PM
    #96
    Bosshoag
    Mr. Doogan
    Virginia Beach, VA
    I like where your heads at as that would totally work if I had a full size spare. But I didn't shell out the extra $250 for another tire when I bought these slightly larger tires. Good thinking though. It probably would have been worth it to shell that out just for this scenario and of course the additional mileage you get out of the set of tires with the fifth.
  17. Feb 27, 2017 at 7:57 PM
    #97
    Hugh Morron
    Bill
    You could still use the spare to rotate your tires. Rotate all the way around and put the spare back under the truck.
    jpmorrisvb likes this.
  18. Feb 28, 2017 at 3:35 AM
    #98
    Bosshoag
    Mr. Doogan
    Virginia Beach, VA
    You absolutely just blew my mind! Good thinking man. I see the light now.
  19. Feb 28, 2017 at 3:38 AM
    #99
    ChadsPride
    Sponsored by TacomaWorld.com
    Whoa
    rhetto and Bosshoag like this.
  20. Oct 3, 2017 at 9:55 AM
    #100
    Avreal92
    Avreal92 Well-Known Member
    1998 White(for now) Tacoma Limited TRD
    Yes, old thread...but it came up when I was searching jack points on my first gen.
    I've always lifted my front corners closer to the tire, kinda under the shock where the three rounded bits hang down(only place my jack can get past the suspension, with a 4" block of wood to even manage that). Is that not a good place? Never had an issue yet, but I'd rather not break anything. I'd post a picture, but don't have one right now.
