Where to purchase 2018 TRD Pro Grille?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 20north, Jan 28, 2019.
  1. Jan 28, 2019 at 6:57 PM
    20north
    20north [OP] New Member
    2018 trod offroad
    I have a 2018 trd off-road and want to swap out the grille with a TRD Pro Grille. What are the best options for purchasing this grille? Would also need the tss sensor component...
  2. Jan 28, 2019 at 7:20 PM
    Jmac2408
    Jmac2408 Well-Known Member
    Justin
    Southern California
    18 TRD Off Road 4x4
    I purchased a knock off grille from Amazon in the range of 100$ or so. Then I purchased the factory toyota tss garnish from eBay for around 50-60$
  3. Jan 28, 2019 at 7:24 PM
    Jmac2408
    Justin
    Southern California
    18 TRD Off Road 4x4
  4. Jan 28, 2019 at 7:34 PM
    bonifacio
    bonifacio Well-Known Member
    Central PA
    2019 Cement Gray Tacoma OR 4x4
    Best option would be go OEM. I've been trying to hunt down a decent TRDFaux Grill. Some have fitment issues and some have the finish wearing off prematurely. Some are decent. I did grab an OEM TRDPro Grill Garnish from eBay for around $50. You could get a good Faux Grill for $140 from one of the member's here or spend a little more for an OEM PT228-35180 TRD for around $200.
  5. Jan 28, 2019 at 7:36 PM
    Whitetail Assassin
    Whitetail Assassin Well-Known Member
    Tedric
    Virginia
    2019 Magnetic Gray TRD Off-Road 6 Speed MT
  6. Jan 28, 2019 at 9:29 PM
    bobcat68
    bobcat68 Well-Known Member
    Greg
    I-O-Wa
    2019 Tacoma DCSB TRD Sport
    Remote start, Homelink mirror
    Picked mine up from eBay for around $75. Fit perfect and looks great.
    1776Taco likes this.
  7. Jan 28, 2019 at 10:16 PM
    guwoptaco
    guwoptaco Well-Known Member
    2018 Magnetic Long Bed OR
  8. Jan 28, 2019 at 10:17 PM
    guwoptaco
    I wound up purchasing an OEM grill from Lowe Toyota because I did not want to get burned twice. It was $190+shipping, which kinda sucked but I didn’t want to deal with another bad grill again.
  9. Jan 28, 2019 at 10:20 PM
    NEPAChuy
    NEPAChuy Well-Known Member
    Jeremy
    2018 Tacoma TRD OR Blue Pearl
    @guwotaco care to elaborate?
  10. Jan 28, 2019 at 10:22 PM
    guwoptaco
    Sure, sorry - this is from my ig post:
    I bought a China grill from madhornets and not only was the plastic insanely cheap feeling and scratched up out of the box, but the ‘Y’ fell off almost instantly. Super glued it back on, and after one night of rain and 2 weeks of use, the paint started corroding.
    If you tap the link I posted above, there are more pictures of the shitty cheap plastic.
  11. Jan 28, 2019 at 10:29 PM
    NEPAChuy
    Jeremy
    Ah, sorry about your bad luck. I went the eBay route (happened to buy grille from bruce-shark and OEM garnish from a Toyota dealer) and the final product fits and looks good. But the install certainly wasn't without its flaws. I ended up using JB Weld epoxy to hold the letter assembly onto the main grille because the holes for the screws weren't properly injection molded. Then, I had issues fitting the OEM garnish into the TSS slot and ended up breaking both bottom tabs of the OEM garnish. So, I used a Dremel tool and polished flat the broken tabs, applied double sided tape to hold the bottom (not really needed), then added self-threading wing nuts to the top pins of the OEM garnish to hold it onto the grille. I've been running my new grille for a few weeks now without issue.
    I'm sure the OEM setup is easier.
  12. Jan 28, 2019 at 10:32 PM
    guwoptaco
    Ah, yes, I didn’t mention that none of the screws threaded either, so I had to get new hardware too. What a pain!
    Glad you found a fix.
    I also broke those tabs as well, but the gorilla tape I used didn’t touch connect to the OEM one for some reason - wound up picking up a new one. Expensive lesson no doubt.
  13. Jan 29, 2019 at 2:23 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I got the OEM grill and garnish for $250 local dealer here.
    Whitetail Assassin likes this.
  14. Jan 29, 2019 at 2:43 AM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    why do people want others to do the work for them,, ever hear of GOOGLE
    https://www.tacomaworld.com/threads/2018-trd-pro-grille-w-tss-p-radar-info-diy.530769/
    https://www.ebay.com/p/OEM-Toyota-T...e-Black-Grille-Insert-Pt228-35170/24007706922
    https://www.amazon.com/Toyota-PT228-35170-TRD-Grille/dp/B01NGTBOKM
    https://parts.toyotaofnashua.com/oem-parts/toyota-2016-2018-tacoma-trd-pro-grille-pt22835170
    the list goes on and on
    na8rboy likes this.
  15. Jan 29, 2019 at 3:27 AM
    bonifacio
    Central PA
  16. Jan 31, 2019 at 12:22 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Anyone know how tall the letters are on these grills?
    Streak09 likes this.
  17. Jan 31, 2019 at 5:49 AM
    Streak09
    Streak09 Well-Known Member
    Dayton O! H! I! O!
    2015 TRD Sport DCLB Barcelona Red
    Wondering the same! Also, anyone have just the letters they want to let go of?
  18. Jan 31, 2019 at 6:14 AM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    You guys with the letters falling off, are you putting the letters right on then putting the grill on the car. Or are you letting the letter's adhesive cure in your house for a day or two before putting the grill on the car
  19. Nov 5, 2019 at 11:35 AM
    Dennisglenn1989
    Dennisglenn1989 New Member
    Dennis
    2019 Toyota Tacoma TRD Sport
    After tons of research and price comparing, I decided to call Toyota to see what they had to say. The guy on the phone quoted me $900 for the grill, $150 for the install. I said, "wait a minute, what". He told me that the garnish is expensive. I told him that I'll proceed to get mine from China for $189, and definitely don't need help installing a plug and play grill for one fiddy. Thought I'd share.
    :duh:
  20. Mar 20, 2020 at 3:55 PM
    Notcris
    Notcris Well-Known Member
    Cristian
    Georgia
    2021 4runner Lunar Rock Trd Pro 2004 Xtra xab red
    None
    I’m looking at that grill too from Lowe Toyota is it the real deal?
