Where to purchase clock spring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Northern Taco, Jan 20, 2017.
  1. Jan 20, 2017 at 9:58 AM
    Northern Taco
    Northern Taco [OP] Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    I think I need a new clock spring as my air bag light is on. Dealer wants $425 for the part, but I have been seeing some on Amazon for $30-$60 but the description of which model years they fit is very vague. Anyone have a part number for an aftermarket one? or any recommendations as there is no way i'm spending $425 for one from toyota. Mine is not covered by the recall either, i tried that one.
    https://www.amazon.ca/Airbag-Spiral-Spring-843060E010-8430648030/dp/B016HMHVPG
    This one any good? lists my model tacoma.
    http://www.ebay.ca/itm/84306-48030-...ash=item5d602b0de6:g:KucAAOSwg3FUjrOC&vxp=mtr
    Just trying to get a feel for is these are any good, seem aweful cheap compared to toyota's price. Anyone on here use one of these cheapies?
  2. Jan 20, 2017 at 3:05 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    don't buy the cheap ebay or Amazon. just get one from the factory unless you want to change it again in a few months
    RugglesTarlek likes this.
  3. Jan 20, 2017 at 3:12 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I got my last one off of eBay. No issues.
    I have got them from the dealer before, I never paid that kind of money
    I rebuild wrecks, so replacing this part is common for me, in case you were wondering.
  4. Jan 20, 2017 at 5:25 PM
    Northern Taco
    Doorman makes one for $170 and comes with a lifetime warranty. This might be the best option?
    How long has yours from eBay been in your Tacoma?
    $425 is Canadian from Toyota.
  5. Jan 20, 2017 at 6:10 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Wasn't this part one of the recalls ? I'm sure they did the spiral thing and a seat belt spring.
  6. Jan 20, 2017 at 6:52 PM
    Northern Taco
    I called and they ran my vin and said my truck isn't under this particular recall. Don't know why not, but if I can get one for cheap enough I don't mind all that much as I'm getting a new frame and everything, so hard to complain too much.
  7. Jan 21, 2017 at 2:26 AM
    koditten
    Kirk
    Central Michigan
    Not a Tacoma, my Tundra has had the ebay ribbon cable installed for 3+ years.
  8. Jan 21, 2017 at 5:44 AM
    george3
    New Jersey
    Well at least you checked it out. Wonder how they determine who gets what and who doesn't? I got mine done. Good luck finding a reasonable priced product that works for you.
  9. Jan 21, 2017 at 6:54 AM
    Northern Taco
    Good to know. For all the time it takes I think I'll save $400 and try the eBay one. Still baffles me how some get recalled and some don't.
  10. Jan 21, 2017 at 8:35 AM
    koditten
    Kirk
    Central Michigan
    Just don't make the mistake I did.
    I don't have wheel puller, but I do have a dent puller/slam hammer with a wheel pulling attachment.
    I hooked it up, sat in the seat and started using the dent puller like you normally do. That steering wheel was being a bitch! I was really giving that puller a work out. Finally the wheel pops off! Unfortunately the weight on the puller kept going! Smacked myself in the fore head! That fuckin' hurt!
    You know how they say good lessons are embarressing, or painful? Mine was both.
  11. Jan 21, 2017 at 8:58 AM
    Northern Taco
    Sounds like something I would do. I'll get a puller from local parts shop, or online. Dealer said they have computer to hook up to truck to disable the air bag, but I assume disconnecting the battery and waiting 15-30 minutes for power to discharge would net the same results? Save me the $100 labour rate.
  12. Jan 21, 2017 at 9:06 AM
    koditten
    Kirk
    Central Michigan
    Yep, disconnect battery and turn on lights to remove any risidual voltage.
  13. Jan 21, 2017 at 9:08 AM
    RugglesTarlek
    RugglesTarlek Well-Known Member
    California
    basic basic basic 14 AC
    Agree that this is an easy diy job... when I did mine, I didn't even need a puller.
  14. Jan 21, 2017 at 9:23 AM
    desertrunner24
    Jake
    Fresno , CA
    Some
    no puller needed to take the wheel off on these trucks. just a little tap from behind. make sure you mark the position of the clocking before removal
  15. Jan 21, 2017 at 9:43 AM
    Northern Taco
    Perfect thanks fellas
