Where to put Hideaway Subwoofer - Passenger or Driver Side ?
Discussion in 'Audio & Video' started by 2016Tacoman, May 19, 2018.
Where to put Hideaway Subwoofer Passenger or Driver Side ?
  1. Drivers side
    10 vote(s)
    52.6%
  2. Passengers side
    5 vote(s)
    26.3%
  3. Doesn't really matter
    3 vote(s)
    15.8%
  4. Don't know
    1 vote(s)
    5.3%
  1. May 19, 2018 at 8:02 PM
    2016Tacoman
    2016Tacoman [OP] Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
  2. May 20, 2018 at 7:08 AM
    coma toy
    coma toy Off Road Taco
    You will have a remote volume control of the bass if its too much or too little. Anywhere else and you are missing out on the thump. If you feel your passenger should have thump, you should add a 2nd Sub.
    P.S. There is more room under the driver seat compared to the pass side.
  3. May 21, 2018 at 10:34 AM
    itsmike
    itsmike Well-Known Member
    SoCal
    2016Tacoman[OP] likes this.
  4. May 24, 2018 at 11:09 AM
    Shiki Shabazz
    Shiki Shabazz Well-Known Member
    Tulsa, OK
    2003 Tacoma Dbl Cab TRD
    Had one in an 01 access cab under the driver seat for a couple years and it was fantastic. Added perfect amount of bass and it doesn't vibrate the mess out of you if that's what youre talking about. Currently have an 03 double cab with the same setup. Id go driver side every time.
  5. May 24, 2018 at 9:11 PM
    2016Tacoman
    J
    After reading your comment I have to agree with your decision for drivers side.
    Good points. :thumbsup:
    Thanks.
  6. May 24, 2018 at 9:43 PM
    itsmike
    SoCal
    Anyone have a picture of their sub installed under a 2nd/3rd gen double cab seat?
  7. May 24, 2018 at 9:52 PM
    JeffP213
    JeffP213 I used to do mods. I still do, but I used to, too
    Jeff
    Central, VA
    15 TRD OR
    JL Audio makes a box for a 10 behind the passenger cab seat. Mine sounds clear and thumps :rockband:
  8. May 26, 2018 at 9:17 AM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    Will not fit under passenger side front due to a cross member on that side but not drivers (3rd Gen). On the drivers side it is snug but will fit. I am not sure the purpose of the passenger side cross member or if it could be removed. That was my intended install but after finding the cross member I decided drivers side was better. For dbl cab many put it behind the rear seats.
    Now as far as thump and getting annoying. When I first installed and was adjusting the remote I could get a heavy thump if I turned the gain up and it did become annoying on the drivers seat at high volume. Once I stopped playing around and dialed it in to my final setting and left it it isn’t as heavy on some songs but it is dialed in and I leave it alone. If you like your bass set to annoyance levels it will bother you under the drivers seat. At my normal bass setting and the music cranked I can rattle the rear window just a bit but it doesn’t bother me under my seat.
