Where's the best 12volt tap?
Discussion in 'Audio & Video' started by thebigk, Feb 27, 2009.
  1. Feb 27, 2009 at 7:27 PM
    thebigk
    thebigk [OP] 6 Double 5 3 2 1
    Ken....
    Odessa, TX
    I want to hardwire my Sirius radio. It's mounted in the cubby in front of the shifter.
    Where's the best place to tap into a 12v source? Under the console? Behind the cigarette lighter?
    I'm installing a USA-Spec adapter next week so I'll have the climate controls and stereo out if that matters. Just looking for the easiest way to route & connect the wiring.
    Thanks!!
  2. Feb 27, 2009 at 7:31 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you can get an add-a-circuit from radio shack and nstall it in the small fuse panel to the left of the steering wheel.....................unless you wanna hardwire straight to the battery, then you'll need to go thru a grommet in the fire wall.
  3. Feb 27, 2009 at 7:43 PM
    4x4Runner
    4x4Runner Now with more Oi Vey! Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
  4. Feb 27, 2009 at 9:01 PM
    gdctaco
    gdctaco Well-Known Member
    georgetown, ont
    06 access cab 4x4 O/R
    rr diff mod in-cab 110
    i wired mine direct to the 12V cig, that way it would turn on and off with the truck.
  5. Feb 27, 2009 at 9:42 PM
    thebigk
    Ken....
    Odessa, TX
    That's more what I was looking for. :D.....how did you get to the wiring on the receptacle?
  6. Feb 27, 2009 at 9:57 PM
    gdctaco
    georgetown, ont
    thats the tough part you have to take the dash apart, and while you have the head unit out you might aswell hook up a direct connect antennea thing. really helps with the sound, no need to set fm trasmiter stations and no interference.
  7. Feb 27, 2009 at 10:02 PM
    thebigk
    Ken....
    Odessa, TX
    I ordered a USA SPEC pa15-toy that's the whole reason to hook up the 12v while I'm at it. The FM transmitter sound is pretty crappy
  8. Feb 27, 2009 at 10:16 PM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    Look at the item I posted. Pull the ACC fuse and put that in its place with the fuse and the fuse for what you will be running. You don't splice wires that way and it turns on and off with the the radio and accessories. And you don't have to pull the whole dash apart. I put one on the FJ to power my CB.
  9. Feb 27, 2009 at 10:34 PM
    thebigk
    Ken....
    Odessa, TX
    That's not to bad an idea. BUT I'm no electronics guru.......so don't lauigh!
    Where do I tie the ground wire in?
  10. Feb 27, 2009 at 10:54 PM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    Find any bolt that ties into the chassis crimp a lug onto the wire and secure it there . On the FJ I pulled down the center console and switch panel and attached it there. I'll get some pics tomorrow and post them up if it helps.
  11. Feb 28, 2009 at 9:44 AM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    You can look at my signature below for the GPS hardwire, should be similar to what you are accomplishing. It's no treat, but at least this prepares you.
    KC's product would probably be a lot faster/easier
  12. Feb 28, 2009 at 4:34 PM
    thebigk
    Ken....
    Odessa, TX
    Nice write up!!! That gave me some ideas. I decided to go with adding a 12v receptacle like you did......but what kept you from splicing into the power wires behind the stereo? I don't REALLY want to disassemble my truck quite that far :D
  13. Feb 28, 2009 at 5:04 PM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    Did you use the Mini ATO's or regular ATO's?
  14. Feb 28, 2009 at 5:34 PM
    mneuls
    mneuls Well-Known Member
    Fort St John, British Columbia, Canada
    5100's and dakar leaf 3"lift, Satoshi grill,
    Bilstein 5100's front and back, dakar 3" leaf springs, Westin bull bar, piaa driving lights, piaa replacement bulbs, H/U, 2x10" mtx tt65 subs, 1000w clarion monoblock, Mtx surround speakers. green wire mod. Flowmaster 40, airaid intake. scanguage II.
    I used an add a fuse for my piaa lights, I have a few spare spots on my fuseblock where there was accessory power, but no fuse in there. I used the ATO add a circut product the same as KC used. worked fine.
  15. Feb 28, 2009 at 9:49 PM
    Chickenmunga
    Keizer, Oregon
    I'm not very electrically adventurous. I knew that I wanted my power exactly like how the cig lighter works, so went straight to the source.
    More than anything though, i really had no clue that the area behind the cig lighter was considered Fort Knox, and I got far enough where it was me vs. truck and I was going to win.
  16. Mar 3, 2009 at 8:37 PM
    thebigk
    Ken....
    Odessa, TX
    Thanks to Chickenmunga & Kilted Chicken!!!!
    The add a circuit & the GPS wiring info worked great!
    Got my Sirius hardwired to the stereo & to the 12v.
    Thanks for you guys hard work to make mine ALOT easier!
    Rep to you both! :D
  17. Mar 3, 2009 at 9:26 PM
    Chickenmunga
    Keizer, Oregon
    :cheers:
    Post a pic if you can!
