Which brand LED bulbs are best ?
Discussion in '3rd Gen. Tacomas (2016+)' started by shawnc, Oct 8, 2016.
  1. Oct 8, 2016 at 7:54 PM
    shawnc
    shawnc [OP] Member
    fall river ma
    2016 tacoma double cab long bed 4x4
    looking for new headlight/ fog and plate led bulbs but looking for good quality stuff .
    Any suggestions ? Thanks!!
  2. Oct 8, 2016 at 9:34 PM
    Element4563
    Element4563 Active Member
    Michael
    Portland, OR
    2016 DCSB OR
  3. Oct 8, 2016 at 11:12 PM
    bomack
    bomack Active Member
    Winnipeg, Canada
    2017 Tacoma DCLB TRD Sport inferno
    Bone stock except bungee cords and husky liners!
    Is there any legal concerns with installing LEDs?
    Where I'm going with this is people who were putting HIDs into headlamps that weren't designed for them and blinding other drivers.
    I'm going from a Mazda with awesome factory HIDs into the Tacoma and concerned and the headlights. Yes small world problems.
  4. Oct 8, 2016 at 11:22 PM
    RBfastback
    RBfastback It's Got Electrolytes
    mike
    FL
    16 mgm TRD off road
  5. Oct 8, 2016 at 11:24 PM
    RBfastback
    mike
    FL
    16 mgm TRD off road
    and ur not going to blind ppl with hid's because the new tacomas have projectors in the headlights so it will have a nice clean cutoff so it doesn't blast everyone in the face
  6. Oct 8, 2016 at 11:45 PM
    MTNHABITOVERLAND
    MTNHABITOVERLAND Well-Known Member
    2016 Tacoma Adventure Camper Build
    Vagabond Outdoors Camper Instagram: @mountainhabit
    On a 16 Tacoma right? Amazon is always saying doesn't fit so just checking.
  7. Oct 8, 2016 at 11:52 PM
    RBfastback
    mike
    FL
    16 mgm TRD off road
    anyone here have the OPT7's for just the high beams?
    looking for an led high beam that's 5500k-6000k but not more dim then the oem yellow.
    that's the only bulb i have that's still yellow.
  8. Oct 9, 2016 at 6:38 AM
    porterican
    porterican Member
    2016 Black Tacoma Limited
    I have the OPT 7 H11 on my Taco, works great!
  9. Oct 9, 2016 at 6:44 AM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
  10. Oct 9, 2016 at 6:51 AM
    jsinnard
    jsinnard Crawl Control and longbed? I has it
    Virginia
    04 DCAB 4X4, 16 QS DCLB OR 4X4
    Mush Mouse likes this.
  11. Oct 9, 2016 at 7:32 AM
    porterican
    porterican Member
    I failed to mention the OPT 7 H11 are used on my low beam.
  12. Oct 9, 2016 at 8:15 AM
    axisofoil
    axisofoil Rocket Surgeon
    Gilbert, AZ
    2016 Silver TRD OR Dcsb 4x2
    All sorts of people have them. Me included.
    Work great in the high beam slot... Really blinds the piss out of people when you flash them for driving around with their brights on.
    Work great in the low beams, too.
    Not great or even acceptable in the fog lamps, at least not if you intend to use them as fog lamps, and too much spread upward to use a driving lights, also.
    All opinions are based on the h11 opt7s.
  13. Oct 9, 2016 at 9:02 AM
    siznarf
    siznarf Everyone my age is older than me...
    Francis
    Stockton
    16 Tacoma
    91 Octane
    Good info on that thread, however:
    Thread was primarily directed to 2nd gen Tacomas with reflector style headlights. LEDs on 3rd gens are fine because of the projector style headlight. There is also a cutoff so you don't blind oncoming traffic.
    That being said, my OPT7s LEDs are underpowered - especially in the rain.
    LEDs will be removed, still looking for a replacement option
  14. Oct 9, 2016 at 3:04 PM
    Element4563
    Michael
    Portland, OR
    2016 DCSB OR
    Yep, I have them in my 2016
  15. Oct 9, 2016 at 3:07 PM
    Unchained 5150
    Unchained 5150 Well-Known Member
    Rick
    Auburn Ma
    Just took out all my LED's because of that thread.
  16. Oct 9, 2016 at 3:43 PM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    Tested opt7, not impressed. Im running piaa h11 led now and like them, but not perfect. Great look, good spread and output but that color that makes em so nice isnt excellent for visibility. Much higher quality than others ive used in the past though and still fit in the tight area for low beams
    EJ347 likes this.
  17. Oct 9, 2016 at 4:31 PM
    16TacomaSport
    16TacomaSport Well-Known Member
    Jon
    Pittsburgh PA
    2016 Double Cab TRD Sport BBP
    Dont waste your money paying for the OPT7 cause it has a name on it. These are the same thing all coming out of the same Chinese facility just companies order in bulk and can have some custom stuff done to make them seem different.
    Buy the SAME exact bulb for half the price. I got these for my low beams and fog lights and they are actually rated a little higher at 7600lm for the pair. I have been pleased with them as far as output and everything. it just takes a little time getting use to the white light vs the stock more yellow color.
    http://www.ebay.com/itm/7600LM-60W-...ash=item35ec69982f:g:HRMAAOSwFdtXyRCO&vxp=mtr
    also that link is LED in a reflector housing. If using in a projector you get none of that crap. Plus if you get extra light scatter when using them in the reflector high beam why would it matter. shouldnt have them on with oncoming traffic anyway
  18. Oct 9, 2016 at 6:42 PM
    =JSG=
    =JSG= Well-Known Member
    Canada
    2017 DC TRD OR 4x4 SB
    Morimoto 2 Stroke lows, Baja designs Squadron-R Sport as fogs, Method NVs
    You got any pics of the install? Either these or Morimoto 2Stroke. You have any issues with the ballasts feeding back into the ECU? And killing the truck?
  19. Oct 9, 2016 at 6:46 PM
    tacoscott16
    tacoscott16 Well-Known Member
    scott
    2018 TRD pro
    I had hoshi for my fog light, like it very much, keep in mine hoshi won't fit in headlight low beam.
  20. Oct 9, 2016 at 7:00 PM
    DrVonEvilSatan
    DrVonEvilSatan Well-Known Member
    Toyota Truck
