Which brand u-joint do you prefer?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JL8Jeff, Nov 4, 2018.
  1. Nov 4, 2018 at 1:13 PM
    JL8Jeff
    JL8Jeff [OP] Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    I think my front u-joint is going bad so I want to replace it. The oem part looks like 04371-04092 (supercedes 04371-04090 and 04371-0K070) for the 2013 2.7 4wd regular cab but I was wondering if any of the other replacement brands are as good or better quality. I'm not seeing a lot of cross references to this part # and most seem to be for the longer trucks with the 2 piece driveshafts.
  2. Nov 4, 2018 at 1:18 PM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    I always use moog or moog hd series u joints and wheel bearings. Always had good luck/use with them especially when running heavier larger tires.
    Fatmonk8 likes this.
  3. Nov 4, 2018 at 1:20 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Had moogs in for a couple of years, now. Working good
  4. Nov 4, 2018 at 1:43 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Spicer
    /thread
    seriously... its what the OEM joints are. Someone can chime in with the Spicer part number for the smaller front driveshaft u joints with the center zerk fitting
    BassAckwards and EatSleepTacos like this.
  5. Nov 4, 2018 at 1:44 PM
    fla_sun
    fla_sun Well-Known Member
    2006 SR5 4X4 AC 4.0 Auto
    I ordered spicer 5-1330-1X u-joints. They look exactly like the original. They were sold as heavy duty but the documentation in the box described them as light/medium duty.
    About $80 something for three delivered from Rock Auto.
    (Rear shaft all joints.) sorry can’t find the front u-joint part numbers.
    BassAckwards likes this.
  6. Nov 4, 2018 at 2:39 PM
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    Do those have the grease fitting in the body cross?
  7. Nov 4, 2018 at 2:56 PM
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
  8. Nov 4, 2018 at 3:04 PM
    Rockbaron1
    Rockbaron1 Well-Known Member
    Pat
    03 Tacoma
    everything
    Pretty sure Matsuba is oem not Spicer (at least it is on first gen Tacoma’s and older pickups).
    http://www.lowrangeoffroad.com/toyota-matsuba-matsui-u-joints-universal-joint.html
    Edit; ok it does not look like these are the oem joints for 2nd gens but they should still fit and they’re made in Japan
  9. Nov 4, 2018 at 3:10 PM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
  10. Nov 4, 2018 at 3:12 PM
    Rockbaron1
    Pat
    03 Tacoma
    everything
    Yeah realized my mistake and edited the post
    MolonLabeTaco likes this.
  11. Nov 4, 2018 at 3:44 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Spicer all the way
  12. Nov 5, 2018 at 8:43 AM
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    Just curious, does anyone know if there is really a difference with the oem ones from the access cab or double cab compared to the standard cab? Oem shows:
    04371-0K080 for the dual driveshaft trucks
    04371-0K070 for the standard cabs
    edit: oops, had the wrong part numbers so updated it
  13. Nov 5, 2018 at 8:46 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Another vote for greasable spicer units
  14. Nov 5, 2018 at 9:13 AM
    Rockbaron1
    Pat
    03 Tacoma
    everything
    Just looking at pictures of the 2 you can see the first one has the c-clips on the outside. And second has c-clips on the inside.
    The u-joint at the pinion should be the same for all Tacoma’s (c-clips on the inside).
    I’ve only ever seen c-clips on the outside of the double cardan joints found on the front half of 2-piece shafts.
  15. Nov 5, 2018 at 10:36 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Spicer or lifetime warranty.
  16. Nov 8, 2018 at 8:58 AM
    safaridave
    safaridave Active Member
    Richmond, Virginia
    06 Prerunner TRD OffRoad
    Pardon my ignorance, but why do the Spicer Ujoints comes with all those snap rings? Different thicknesses?
  17. Nov 8, 2018 at 9:13 AM
    fla_sun
    You guessed correctly. Use what ever fits the best.
    Approximant measurements:
    copper .0595"
    grey .0605"
    green .0625"
    I just replaced three of these yesterday and used the largest snap ring that would fit.
