Which cam lube to use for rebuild?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, Aug 30, 2015.
  1. Aug 30, 2015 at 8:14 PM
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
  2. Aug 30, 2015 at 9:53 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    I'm bias to ARP assembly lube. Torco is another good choice IMO
  3. Aug 30, 2015 at 10:40 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Any name brand assembly lube is just fine. It just provides protection for the short time during initial startup until the engine lubrication system gets up to pressure and flow.
    As I stated many years ago we just used STP Oil Treatment ( honey ) for assembly lube.
    BUZZCUT likes this.
  4. Aug 31, 2015 at 8:07 AM
    foampile
    Mid-Atlantic
    I know about the assembly (or break-in) lube but someone told me to use a different substance on cams only, something that is thicker than oil, almost like lithium based grease. they said that was better than assembly lube for cams.
  5. Aug 31, 2015 at 8:16 AM
    DEMikey
    DEMikey Mr. Badwrench
    mikey
    delaware
    2013 red taco
    100XR, OTW Surf Rod Rack, Toytec 3" lift, +1 on tires
  6. Aug 31, 2015 at 8:43 AM
    foampile
    Mid-Atlantic
  7. Aug 31, 2015 at 11:20 AM
    DEMikey
    mikey
    delaware
    2013 red taco
    assembly lube is not break in oil. the brad penn stuff i listed is break in oil.
    assembly lube? like stated above, the stuff you listed, STP, i used to use lucas oil stabilizer and engine oil 5050 mix.
  8. Aug 31, 2015 at 11:25 AM
    foampile
    Mid-Atlantic
  9. Aug 31, 2015 at 2:10 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Assembly lube will be just fine. You're not breaking in your cams. You just need something there until the oil can get circulated and displace it.
    foampile[OP] likes this.
  10. Aug 31, 2015 at 2:12 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Permatex makes fine products imo. Now get that thing back together, I'm getting impatient! :)
  11. Sep 2, 2015 at 4:24 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Somebody was full of shit, to be blunt. All assembly lubes that I have used is thicker than oil.
    Did you replace the Cam Bearings? If no I would go with any name brand assy lube and let it roll,
    Torspd and Lord Helmet like this.
