Which differential grease?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ram1009, May 18, 2025 at 11:42 PM.
  1. May 18, 2025 at 11:42 PM
    ram1009
    ram1009 [OP] Active Member
    Robert
    Tacoma 2008 Access Cab White 2.7L Engine, Auto Trans
    I'd like to change my differential grease but Toyota wants me to take the truck to a
    Toyota mechanic and so there is no need to tell me what grease to use. I hope someone here can help.
  2. May 19, 2025 at 12:26 AM
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    Differentials don’t use grease per se. . They are lubricated with gear lube. Usually 75W-90 multiple viscosity. Check your owners manual for exact weight and amount needed. Front and rear use same weight but amount probably different. Not a hard DIY job.
  3. May 19, 2025 at 1:10 AM
    ram1009
    Robert
    Well, the owner's manual says nothing about what goes inside the differential nor the quantity. That's why I'm here. Thanks for the reply.
  4. May 19, 2025 at 1:14 AM
    Cement_wheels
    Then try the search function. There is probably 100 threads on Gen 2 diff service.
    eherlihy likes this.
  5. May 19, 2025 at 1:25 AM
    Cement_wheels
  6. May 19, 2025 at 1:27 AM
    Kennyluu611
    Kennyluu611 Well-Known Member
    Kenny
    SoCal
    2010 Tacoma DCSB Prerunner 4x4
    King 2.5 JBA HD UCA Dakar Rear Leaf US Off Road Bumper Winch 4x4 Converted TRD Supercharger
    Here are your options. Choose from one of the three and follow the instructions per thread write-up. For future reference you can use the Mod & Tutorial > 2nd Gen (05-15) How-To or search on the top right corner under inbox and alert.
    https://www.tacomaworld.com/threads/changing-differential-fluid-a-step-by-step-how-to.24545/
    https://www.tacomaworld.com/threads/front-diff-and-transfer-case-oil-change-howto.147631/
    https://www.tacomaworld.com/threads/diy-rear-differential-fluid-change.830622/
  7. May 19, 2025 at 2:12 AM
    ram1009
    Robert
