Which front camera make/model and where mounted on 2018 Limited
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoma3rdGen, Jan 28, 2019.
  1. Apr 4, 2019 at 11:00 AM
    #81
    Sgt.Tee
    Sgt.Tee Well-Known Member
    Pete
    NE Pa
    2019 MGM SR Tacoma 4&4
    That is good, and the price of this camera is very reasonable
  2. Apr 4, 2019 at 11:02 AM
    #82
    porterx
    porterx Well-Known Member
    Thanks. I'll probably use this one for a while. If I run across something with a lot higher resolution that's plug and play, I'll probably get it.
  3. Apr 4, 2019 at 11:05 AM
    #83
    HelloMyNameIs
    HelloMyNameIs I know words, I have the best words.
    2018 TRD Off Road in Cement
    OME 2885, Billie 5100s, HS Prog AAL, 255/85r16 Cooper ST Maxxs
    Keep in mind you'll still be limited by the resolution of the head unit. (Trying to figure out what that is)
    porterx[QUOTED] and Sgt.Tee like this.
  4. Apr 4, 2019 at 11:10 AM
    #84
    Sgt.Tee
    Pete
    NE Pa
    Going to order this now. I have my helper who will install for me, I should say I will be helping him, guys this is a great setup, thanks for posting and all the advice.
  5. Apr 4, 2019 at 11:12 AM
    #85
    porterx
    Oh. Hadn't thought of that. I'd be curious to know.
  6. Apr 4, 2019 at 11:14 AM
    #86
    HelloMyNameIs
    I'm sure you guys won't have an issue! If you've never run anything through the firewall, I straightened out a wire hanger then made a small hook at one end, then taped the wires to that. Just poke through the factory boot/grommet where the wiring harness goes in straight back from the corner where the battery is. Once it is through a few inches, pull it from the other side instead of pushing from the engine bay; that way you avoid nicking the insulation of any factory wires.
    porterx likes this.
  7. Apr 4, 2019 at 11:16 AM
    #87
    HelloMyNameIs
    porterx[QUOTED] likes this.
  8. Apr 4, 2019 at 11:23 AM
    #88
    Sgt.Tee
    Pete
    NE Pa
    I never pressed the mode switch on my truck yet, what does it do. I understand once you get this camera system you can switch between backup camera and the new camera you installed, but without me going up what does the mode switch do.
    porterx likes this.
  9. Apr 4, 2019 at 11:24 AM
    #89
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I've never found a camera that's comparable to the stock rear one.
  10. Apr 4, 2019 at 11:25 AM
    #90
    Sgt.Tee
    Pete
    NE Pa
    This setup is unbelievable, it is reasonable priced and super easy to install, too bad they do not make a record mode so if you get in a accident etc. you can record.
  11. Apr 4, 2019 at 11:30 AM
    #91
    HelloMyNameIs
    The mode button cycles through audio inputs (AM,FM,BlueTooth,iHeart,AUX and USB).
    After install, it still works that same way, but a double tap will make the forward facing cam appear on screen. You can then hit the down arrow to see the rearview camera. Hitting the mode button once again while the camera is up will make the head unit show whatever it showed before the camera came up.
    porterx likes this.
  12. Apr 4, 2019 at 11:32 AM
    #92
    HelloMyNameIs
  13. Apr 4, 2019 at 11:41 AM
    #93
    Skydvrr
    Nick
    YMH
    Black '17 OR
  14. Apr 4, 2019 at 11:44 AM
    #94
    Skydvrr
    Nick
    YMH
    Black '17 OR
  15. Apr 4, 2019 at 11:46 AM
    #95
    HelloMyNameIs
    Huh, I don't know man. How old is your setup? The camera has "upgraded" in the name, like changed the hardware.
    I don't think the Car Solutions module would make the picture any better itself but who knows.
  16. Apr 4, 2019 at 11:47 AM
    #96
    Sgt.Tee
    Pete
    NE Pa
    Cool, thanks for the explanation
  17. Apr 4, 2019 at 11:47 AM
    #97
    porterx
    Also, long pressing the mode button pauses and restarts my podcasts.
  18. Apr 4, 2019 at 11:54 AM
    #98
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Can u post a side by side of yours? Front / rear? I guess I did get mine a few months back.
  19. Apr 4, 2019 at 11:58 AM
    #99
    Sgt.Tee
    Pete
    NE Pa
    Just placed my order. If anyone installs the third camera , please post it up and how it operates off the same mode switch. I could use a extra camera mounted to keep eyes on my dog. He likes to nibble.
    porterx likes this.
  20. Apr 4, 2019 at 11:58 AM
    #100
    HelloMyNameIs
    Yeah I should have a chance later today.
    Skydvrr[QUOTED] likes this.
