Which fuses control dome lites?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brny67, Feb 20, 2012.
  1. Feb 20, 2012 at 10:29 AM
    brny67
    brny67 [OP] Well-Known Member
    Bill
    Moyock NC
    08 TRD Sport A/C
    I have an issue with my two dome lites,my clock and my overhead lite not working, a few months back I put in a dimming mirror and when i took off the big plastic compass/lites/sunglass holder off, a couple of wires pulled out of this little white clip, to make a long story longer, does anyone know what fuse controls those things, i have looked at all the fuses and they seem that they are all good, can the fuse be bad even though the filiment is still intact, hopefully this makes some sense.?? any help wouldbe very appreciated.
  2. Feb 21, 2012 at 10:06 PM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    So your clock dosent light up when you turn your lights on? The fuse is next to the battery. OME or something similar to that. Fuses should be good unless they are broken. Id just try another fuse, see if it works.
    You can get the extra small mini fuses at the dealership, have had hard time finding them before.
  3. Feb 23, 2012 at 5:27 PM
    brny67
    Bill
    Moyock NC
    08 TRD Sport A/C
    tnx i will check that 2morrow, let u know if that works
  4. Feb 24, 2012 at 7:29 AM
    brny67
    Bill
    Moyock NC
    08 TRD Sport A/C
    Hey man I just wanted to let u know that u r the man, it would of probably took me another 6months to a yr to figure out that I had fuses under my hood:eek::ohsnap:how slow am I? But anywho got new mini's @ advance auto and got wires hooked back up to the plastic clip and evrything works again, can't thank you enough for the heads up.
    Tnx,
    Bill
