Which gear oil in R155F transmission?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1moonshine2, Sep 16, 2011.
  1. Sep 16, 2011 at 8:24 PM
    1moonshine2
    1moonshine2 [OP] Well-Known Member
    Appalachian Mountains in VA
    Tacoma 4x4, 4cyl, 5spd, reg cab
    I've noticed rough 1st to 2nd shifts since I've owned this truck. Also, does not want to go into 1st gear unless come to a complete stop. Both are worse until the transmission warms up good. With winter coming, I want to change out the transmission gear oil. Which will give better shifts, Amsoil MTG GL-4, or the Redline MT90 Gl-4? Just wanted to hear from those who have used either or both. Thanks!
  2. Sep 16, 2011 at 8:26 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    Both of my brother's jeeps won't shift into first unless stopped. I would think the same on a truck.
  3. Sep 16, 2011 at 8:29 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Redline MT90 is pretty popular. I use AMSoil Severe Gear 75w-90. I also have the URD short shifter which helps the shifting more than the gear oil IMO.
