Which gear oil type
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fly4food84, Feb 1, 2010.
  1. Feb 1, 2010 at 8:41 AM
    fly4food84
    fly4food84 [OP] Active Member
    New Orleans, LA
    PreRunner
    I have an 07 Tacoma, 4x2 Pre-Runner Double cab and I'm currently at 50k miles and think it's time to change my gear oil. The problem is I don't know if I have a limited slip or not and I know the LS requires additive.
    I've looked in the owner's manual and it tells me to use GL-5 for non Limited slip diffs and GL-5 for Limited Slips FOR Limited slip diffs.
    I looked on the actual differential for any markings and don't see anything relevant. Any info is appreciated.
  2. Feb 1, 2010 at 8:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If you have an LS diff, you should see a sticker that says "LS Diff oil only"
