Which metra wire harness for 07 access cab
Discussion in 'Audio & Video' started by blacksandtaco, Apr 16, 2009.
  1. Apr 16, 2009 at 8:07 AM
    blacksandtaco
    blacksandtaco [OP] Well-Known Member
    Tyler
    Kansas
    07 Access TRD Sport 4X4
    Viper remote start/alarm, Kenwood Excelon DNX 9140 in -dash Nav and DVD, Anzo black headlight, FoldaCover tonneau cover, BedRug carpeted truck bed, Pop-A-Lock electric tailgate lock, Level 8 MK6 (16x8), Toyo Open Country AT2 (LT265/75R16), Fold-A-Cover Tonneau, Bilstein 5100s front, Rear Leaf Suspension TSB, AVS in-channel front window vents, AVS Aeroskin hood protector,
  2. Apr 16, 2009 at 10:52 AM
    tacomajason
    tacomajason the anti mpg
    Arkansas
    09 ssm ac oc 6mt 4wd
    stock (for now)
    which head unit do you have?
  3. Apr 16, 2009 at 1:34 PM
    blacksandtaco
    Tyler
    Kansas
    Have purchased Kenwood DNX7140
  4. Apr 17, 2009 at 8:21 PM
    blacksandtaco
    Tyler
    Kansas
    Anyone have any ideas?
  5. Apr 17, 2009 at 8:28 PM
    blacksandtaco
    Tyler
    Kansas
    Anyone have any ideas? I have the Scosche TA02B and I think it will work but then I found the Metra 80-1761 and Metra 70-1761 that are both apparently for 1987 Toyota and up. The 80-1761 says it's a "Smart" harness, whatever that means. Has anyone used either of these Metra harnesses for their DDIN head units? Again I'm installing the Kenwood DNX7140 in my 07 access cab within the next week and am curious which wiring harness is going to work best. Thanks for your help.
  6. Apr 18, 2009 at 3:19 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    A wiring harness is a wiring harness. Check for the required leads, they should be labeled, and match them up to your deck harness. If you have extras on your deck harness then maybe you should look into a different harness. I'm holding the TA02B in my hand right now and It looks like it uses all pins but two. Probably a good choice.
    Now if you have a JBL stereo, DON'T USE THAT HARNESS. You need a totally different setup for a JBL.
  7. Apr 19, 2009 at 12:13 PM
    blacksandtaco
    Tyler
    Kansas
    Thanks Brian. I'll give it a whirl and see what happens.
