Which OME Springs (885s or 886s)?
Discussion in 'Suspension' started by NumNutz, Nov 22, 2012.
  1. Nov 22, 2012 at 4:59 PM
    NumNutz
    NumNutz [OP] One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    Yea, but I'm only looking for 2" of lift. Going for an overland rig, not rock crawler. Would UCAs be suggested at that amount of lift?
  2. Nov 22, 2012 at 5:24 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    Do add a top plate spacer do you have to breakdown the coil over?
  3. Nov 22, 2012 at 5:41 PM
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    Yes. But the OME doesn't come assembled anyway.
  4. Nov 22, 2012 at 5:47 PM
    Hurtin Albertan
    Hurtin Albertan Free Man
    Duck
    on the road less traveled
    The mud hides the tree scrapes in the paint
    Huskyliner floor mats
    Subbed for reference, springtime project
  5. Nov 22, 2012 at 6:06 PM
    Large
    Large Red
    You are in a pickle. I have a brute force, xrc8 and ran 885s with 5100s and it sagged about 7/8" afterwards. Before the weight I had about 2.5" of front lift. I'd go 885s and 1/4" spacers
  6. Nov 22, 2012 at 6:13 PM
    TruKnight
    TruKnight Well-Known Member
    Tru
    Arkansas
    Autobot Mall Crawler
    read build thread
    should be fine with stock uca's at 2"
    yep youll have to take apart the stock coil assembly, change out whatever, then reinstall
    lookin forward to seein your build tho =)
  7. Nov 23, 2012 at 5:20 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    Thanks large. You're also a DC and I've always read that there is a difference between DC and AC when it has come to lift height. I don't know if it is substantial or not though.
    What's the difference between the "1/4" Thick Aluminum Top Spacer" and the "10mm Lift Enhancer Kit" available at wheeler's?
    10mm - 1/4" - One is significantly more expensive and one gives more lift, but how do they differ?
  8. Nov 23, 2012 at 7:23 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The 10mm spacer kit is a pair and includes longer studs , providing 5/8-3/4" of additional lift
    The 1/4" plate is sold as a single , no longer studs ( not needed ) and provides 3/8-1/2" of lift
  9. Nov 23, 2012 at 9:41 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    Okay thanks. And to correct tacoma lean would I buy two 1/4" plates for the driver side? And I would assume that would require longer studs?
    Sorry for my ignorance, this is the weird side of TW I don't understand yet.
  10. Nov 23, 2012 at 9:42 AM
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    I only had to use one 1/4 spacer to correct the lean.
  11. Nov 23, 2012 at 9:44 AM
    Large
    Large Red
    I think he wants 1/2" on the driver and 1/4" on the passenger. No need to stack two 1/4" spacers, just buy a 1/4" and a 1/2" spacer from Toytec, assuming you have the taco lean (I didn't)
  12. Nov 23, 2012 at 9:52 AM
    OZ-T
    Peter North
    British Columbia
    Are you planning on using OME shocks ?
  13. Nov 23, 2012 at 10:31 AM
    mh.meier
    The Doctor
    Commiefornia
    ^^^---- thats a good question
  14. Nov 23, 2012 at 10:49 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    As I said in the original post, I was hoping to use the 5100s I have now. I have heard that you shouldn't use 5100s when running the 886s.
  15. Nov 23, 2012 at 11:25 AM
    #35
    OZ-T
    Peter North
    British Columbia
    My bad , I didn't go back and look
    My point being , with OME shocks , you can correct taco lean with the OME 5mm trim packer that goes on the bottom of the shock , below the coil and then just put 1/4" top plate spacers in both driver and passenger
    No , you shouldn't run 5100's with 886's IMO
  16. Nov 23, 2012 at 11:32 AM
    #36
    NumNutz
    Virginia Beach, VA
    Lots.
    I'm no forum Nazi. Didn't mean to come off that way if I did.
    But, you're saying I can't use that 5mm trim packer with 5100s it sounds like?
  17. Nov 23, 2012 at 11:39 AM
    #37
    OZ-T
    Peter North
    British Columbia
    No worries
    No , the 5mm trim packer only works with OME shocks
  18. Nov 23, 2012 at 11:52 AM
    #38
    NumNutz
    Virginia Beach, VA
    Lots.
    So going with 885s, would you suggest the 1/4" spacer or the 10mm spacer under these criteria:
    -Hybrid bumper - 125-150lbs
    -90lb winch
    -With a desired 2-2.5" of lift
  19. Nov 23, 2012 at 12:07 PM
    #39
    OZ-T
    Peter North
    British Columbia
    10mm driver ( with longer studs ) , 1/4" passenger
  20. Nov 23, 2012 at 12:34 PM
    #40
    NumNutz
    Virginia Beach, VA
    Lots.
    Little mix and matching. Thanks OZ!
