Which plugs? 1998 2.7
Discussion in '1st Gen. Tacomas (1995-2004)' started by SpeedoJosh, Apr 22, 2013.
  1. Apr 22, 2013 at 7:31 AM
    SpeedoJosh
    SpeedoJosh [OP] Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    Thinking I'm going to go ahead and change out plugs and wires on the tacoma. Hoped on Rockauto, and realized there are about 15 different plug types.
    I've heard either use NGK or Denso platinums. Well there are about three different kinds of each, as well as iridium ones.
    Any certain ones I should go with?
    Searching revealed to go with the NGK wires, so that should be easy.
    Before you post, "Get OEM", the OEM markup is ridiculous on every part out there, so not going that route.
