Which rear diff fluid??
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hektor, Jan 4, 2013.
  1. Jan 4, 2013 at 11:26 AM
    Hektor
    Hektor [OP] Well-Known Member
    Texas
    04 Tacoma 4x4 TRD DC v6
  2. Jan 4, 2013 at 12:37 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Mobil 1 cause it is available. Most places I can't get Redline or Royal Purple w/o having to order it.
  3. Jan 4, 2013 at 2:34 PM
    Devout
    Devout Well-Known Member
    Seattle
    03 TRD 4X4
    None yet
    I like Redline because it is a Type V synthetic, whereas Mobil is a type IV.
    I believe Royal Purple is also a Type V.
  4. Jan 4, 2013 at 2:40 PM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    Wrong.
  5. Jan 4, 2013 at 2:43 PM
    Hektor
    Texas
  6. Jan 4, 2013 at 2:50 PM
    GP3
    California
    4X4 TRD Off Road
    Oil type:
    Hypoid Gear Oil API GL–5
    Recommended oil viscosity:
    Front:
    SAE 75W–90
    Rear:
    Above –18C (0F)
    SAE 90
    Below –18C (0F)
    SAE 80W or 80W–90
  7. Jan 4, 2013 at 3:33 PM
    Hektor
    Texas
    One last quick question. Im using toyota type 4 for the transmission, ot should be any problem running synthetic on the rear diff correct??
  8. Jan 4, 2013 at 3:34 PM
    LexusIS808
    LexusIS808 Well-Known Member
  9. Jan 4, 2013 at 3:35 PM
    Devout
    Seattle
    03 TRD 4X4
    None yet
    Show me where it says Type V in that literature. :rolleyes:
  10. Jan 4, 2013 at 3:36 PM
    LexusIS808
    toyota type 4 is correct and you need 4-4.5 quarts. the manual is an error.
  11. Jan 4, 2013 at 3:51 PM
    Devout
    Seattle
    03 TRD 4X4
    None yet
    I may have caused some confusion, so I'll try to clarify;
    GL vs Type.
    GL-4 is for bronze syncos and other gearboxes with bronze.
    GL-5 is for gearboxes without bronze. One of the friction modifiers in GL-5 will chemically attack bronze.
    Type IV synthetic is a stabilized Dino oil the Mobil won the right to call synthetic by suing the FTC for the right to do so.
    Type V is a truly synthetic ester formulated turbine oil. The demands of jet turbine bearings far exceed those of a gasoline piston engine.
    So, back to the original question. I do not have a Taco manual in front of me so I can't answer the weight question, but I can answer a few others.
    Don't run GL-5 in a tranny that specifies GL-4 or you will ruin it.
    MOST differentials run GL-5.
    Diff oil with the limited slip additive can be run in NON limited slip rear ends, and diff oil without the limited slip additive can be run in limited slip rear ends PROVIDED YOU INCLUDE THE FRICTION MODIFIER ADDITIVE.
  12. Jan 4, 2013 at 3:55 PM
    Devout
    Seattle
    03 TRD 4X4
    None yet
    Is that for the tranny or rear diff? :)
  13. Jan 4, 2013 at 3:59 PM
    LexusIS808
  14. Jan 4, 2013 at 4:11 PM
    Hektor
    Texas
    For tranny
  15. Jan 4, 2013 at 4:16 PM
    Hektor
    Texas
  16. Jan 4, 2013 at 4:21 PM
    LexusIS808
    yah took me FOREVER to make my decision but redline 58304 75w-90 NON limited slip and you need EXACTLY 3 quarts. That works! Have it iin my rear diff since late 2011 and NEVER had any problems. GO FOR IT!! cheap on Amazon!! free ship too
  17. Jan 4, 2013 at 4:23 PM
    GP3
    California
    4X4 TRD Off Road
    I didn't know GL rating was different from "Type". News to me.
  18. Jan 4, 2013 at 4:44 PM
    Devout
    Seattle
    03 TRD 4X4
    None yet
    I understand. I'm always learning more about lubricants too. :)
    It can get tough to cut through the marketing hype and internet rumors sometimes.
    Kevin Cameron and Motorcycle Consumer News have published some really good information in the past.
