Which Spacer/AAL lift is better
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rdo8, Jun 10, 2010.
  1. Jun 10, 2010 at 8:37 PM
    rdo8
    rdo8 [OP] Member
    robert
    mississippi
    06 trd sport 4x4
    toytec 3" spacer w/ AAL in rear.
    i am trying to decide between toytec 3" w/ AAL and diff drop down and 1 from extremetrucktoys.com. I have a friend that has the 1 from extreme and he says its quality stuff. I noticed that they use pro comp parts on the AAL, but I also see alot of people on here that have went with toytec. Both use T6 aluminum on the spacer, and extreme is about $40 cheaper also. any input would be great.
  2. Jun 10, 2010 at 8:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    All spacers are about the same. The only difference is if they are a Top plate type or Pre load type.
  3. Jun 10, 2010 at 8:38 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    I would go toytec
  4. Jun 11, 2010 at 2:26 AM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    Whatever aal you go with, just make sure it has the anti-friction pads... Not a guarentee, but better than not..
  5. Jun 11, 2010 at 2:30 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Procomp anything sucks. I used to have procomp aal's and they flattened in 6 months and a friend of mine had them in his toyota and he snapped one right in half after about a year.
