which transmission cooler?
Discussion in '4 Cylinder' started by themeat424, Oct 16, 2012.
  1. Oct 16, 2012 at 9:51 PM
    themeat424
    themeat424 [OP] Active Member
    NY
    12 Regular Cab 4x4 Auto
  2. Oct 16, 2012 at 9:53 PM
    bjasper
    bjasper Well-Known Member
    Brian
    Carmel, CA
    06 TRD PreRunner
    Dad's truck, minor mods.. Saving for my own :)
    Good question. :)
  3. Oct 28, 2012 at 2:30 PM
    themeat424
    NY
    Any suggestions? I live in NY and it can get pretty cold in the winter (occasional single digits), so I'm wondering if the fluid will be running too cold ( or even gel up? ) if I put in a larger cooler rated for 5000lbs. I'm also hesitant to put in a light duty cooler that's rated to 2500lbs as my taco can tow more than that. I live in a mountain area where I have a good amount of steep inclines and the 4 cyl is frequently hunting for gears, so even when not towing the tranny cooler seems like a good idea, I just can't figure out which one to go with...
  4. Oct 28, 2012 at 2:46 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    You're not going to find them at Pep Boys, but higher end coolers have a thermal bypass that diverts the fluid around the cooler until it needs cooling.
    Expect $200+
  5. Oct 28, 2012 at 5:17 PM
    themeat424
    NY
    Do you think such a cooler would be necessary in cold climates? If so, can you name any brands?
  6. Oct 28, 2012 at 5:31 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I'd recommend it in colder climates, especially if you commonly make short trips to work/class where the engine doesn't get up to temperature and maintain that level for a while.
    Here's a thread on Yotatech that seems to disagree with me:
    http://www.yotatech.com/f2/transmission-coolers-low-temps-bypass-thermostats-tests-results-200965/
    Either way, I would be looking to a higher quality cooler from B&M. They and Hayden have been in the business for a very long time, but Hayden has always been more low-end mass-sales oriented. Quick and easy installation and "okay" performance.
    I'm not fond of their typical mounting method... run a modified zip-tie through the radiator and condensor core.
  7. Oct 28, 2012 at 6:37 PM
    themeat424
    NY
    Seems like the B&M is the cooler to go with.
  8. Oct 28, 2012 at 6:45 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I used their products on my '69 Camaro and '67 Chevelle back in the 80s.
    These days, for a "shift kit", I'd go with TransGo, but B&M would be my 2nd choice if TransGo didn't make a kit for my trans.
  9. Oct 28, 2012 at 6:52 PM
    themeat424
    NY
    The bypass system in the B&M seems like it will do the trick when it gets cold. I actually remember glancing over the bypass feature when I first came across the B&M coolers while reading the "towing bible". If it gets really cold to people just cover up the coolers?
  10. Oct 28, 2012 at 7:01 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I wouldn't cover the cooler if you bypass the factory cooler.
    But yes... if you run the aftermarket inline with the OEM cooler, you can leave it covered and it'll be like you're running stock (except for the part of the radiator that will also be covered).
  11. Oct 28, 2012 at 7:40 PM
    themeat424
    NY
    I appreciate the help rich. I was originally hoping you would chime in.
  12. Oct 28, 2012 at 9:30 PM
    Scott SD
    Scott SD Member
    I just went though this decision a couple of weeks ago. I have a 2.7 PreRunner DC and do not normally tow very much. Maybe once a year. But, in a few weeks I am going back east and will tow my trailer. Total weight will be 3000 lbs. I wanted to add the tow package, so I bought the factory hitch and wiring harness. For the trans cooler I did not like the mounting methods of anything aftermarket. I even have 3 different sized coolers in my stash in the garage, so it would have been cheap as I'd only have to buy the hose. And I could fab up some brackets, but that was way too much work for my schedule. I decide just to buy the factory cooler for the V6 model. It works fine to tow 7000 lbs (?) It was way overpriced. After figuring out what pieces to buy, it was easy to install.
  13. Oct 29, 2012 at 6:33 PM
    Mr. Pick
    Mr. Pick Well-Known Member
    Middle TN
    '12 AC, SR5, 2.7L, Auto
    If you don't mind, would you share the part #'s you came up with for the factory cooler install? Thanks.
  14. Oct 30, 2012 at 10:07 AM
    Eddie98
    Eddie98 Active Member
    Are you going to be towing a lot? I don't see the use of it if you are not towing all the time.
  15. Oct 30, 2012 at 9:05 PM
    Scott SD
    Scott SD Member
    I bought everything from this dealer because it was the cheapest I could find. Still way overpriced.
    http://www.villagetoyotaparts.com/s...riveline=6159&ukey_trimlevel=0&modelYear=2012
    You need to buy:
    32920
    32906
    32943
    32943A
    32921R (QTY ?, can't remember)
    90080-11371 (QTY 3)
    90119-A0056 (QTY 1)
    I didn't even have to take the grill off. Just took a little patience with the correct tools.
    Good luck.
  16. Oct 30, 2012 at 9:11 PM
    Scott SD
    Scott SD Member
    Forgot to mention that I did not buy 32943A. I cut the stock hose and lengthened it with some standard Gates trans cooler hose. I spliced them together with a coupler and some factory clips. It looks stock, but if I did it again I would just buy the $37 32943A hose.
  17. Oct 30, 2012 at 9:21 PM
    AlphaEcho2k5
    AlphaEcho2k5 Well-Known Member
    Adam
    Hurlburt Field, FL
    '02 4Runner
  18. Oct 31, 2012 at 7:01 AM
    Mr. Pick
    Middle TN
    Thanks Scott. You're right, that is pricey, but I like the clean factory look.
  19. Jun 30, 2013 at 6:03 PM
    TwzteD
    TwzteD Well-Known Member
    Kyle
    St Lucie Fl
    2013 4x4 reg cab Auto
    2013 4x4 reg cab, 2011 4runner sr5 rims, 265 general grabber at2's, 5100's All 4 corners with fronts at .85, De badged, Egr Rainguards, Led tail lights, Int wipers, fog lights, Trailer Hitch, POwer locks+ keyless entry, Extang Solidfold Bed Cover, WeatherTech Mats, Stubbie Antenna, Trd Skid Plate, Tint, Scanguage, Cargo net in bed, Sound Ordnance B-8PT, FULID FILM Under Coat.
    hey did you ever install the cooler? if so how did it turn out?
