Which type of lug nut do I need to buy?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hesher Lord, Jul 14, 2019.
  1. Jul 14, 2019 at 2:20 PM
    Hesher Lord
    Hesher Lord [OP] Well-Known Member
    Biloxi, MS
    I will be replacing the factory wheels on my '09 PreRunner next week with these: https://tinyurl.com/y54znmhw
    I would like to get some black lug nuts to match the wheel. Forgive my ignorance, but what type would I need? I know the OEM style are Mag Seat style, but I don't know if that's what I would need for these. The wheel size I'm getting is 17x8"/6x139.7mm, 0mm offset. Would these work? (https://tinyurl.com/yypazux5)
  2. Jul 14, 2019 at 2:23 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  3. Jul 14, 2019 at 2:24 PM
    Hesher Lord
    Biloxi, MS
    Those don't fit the truck.
  4. Jul 14, 2019 at 2:29 PM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    Yeah what you linked works, what you want is acorn (closed end) bulge (the taper seat bulges out past the hex, handily keeps your socket from rubbing the wheel).
    I prefer to keep the 21mm hex, because reasons, but there's also a decent chance you'd end up needing a thin-wall socket if you did, or you might not be able to fit one at all... so a 19mm hex would win in that case. Just remember your stock lug wrench won't work anymore if you buy 19mm ones... preferably before ending up on the side of the road with a flat.
    Hesher Lord[OP] likes this.
  5. Jul 14, 2019 at 2:34 PM
    Hesher Lord
    Biloxi, MS
    Great! I'll have to pick up a 19mm lug wrench then. I appreciate the help.
  6. Jul 14, 2019 at 3:18 PM
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    Just remember to keep a stock set of lugnuts if you still plan on using your stock spare.
  7. Jul 14, 2019 at 3:23 PM
    Hesher Lord
    Biloxi, MS
    Good call, I will do that and keep them in the glove box.
    Grey 2015[QUOTED] likes this.
  8. Jul 14, 2019 at 4:43 PM
    Grey 2015
    Skip
    Loxahatchee Florida
    2015 Tacoma
    I keep a set under the back seat.
  9. Jul 14, 2019 at 5:38 PM
    fb40dash5
    11 V6 AC 4x4
    As long as you have a steel spare, regular cone seats should work fine... that's what you get with steelies anyway.
  10. Jul 15, 2019 at 6:47 AM
    Grey 2015
    Skip
    Loxahatchee Florida
    2015 Tacoma
    True, but if you look at the lug nuts they recommend with that wheel it says not for use with OEM wheels.
  11. Jul 16, 2019 at 9:07 AM
    fb40dash5
    11 V6 AC 4x4
    True, but if you look at the lug nuts they recommend with that wheel, they're also M14 instead of M12... so I'm not exactly trusting anything there at that point. That's why I find good part numbers and then check them on Amazon when buying car parts... their cataloging blows.
