Which type of spacer is better?
Discussion in 'Suspension' started by Inacoma, Sep 4, 2011.
  1. Sep 4, 2011 at 12:57 PM
    Inacoma
    Inacoma [OP] Member
    thomas
    Western N.C
    07 DC TRD sport
    Bone Stock (for now)
    I am looking to order a 3 inch lift kit, and have noticed that there are two types of spacers? Those that bolt on top of spring, and need coil to be compressed. And those that get bolted on top of the whole assembly, and dont need coil to be compressed. Any ideas, I am looking for the better ride of the two, No real off roading in my future other than a few camping trips, Thanks!
  2. Sep 4, 2011 at 1:08 PM
    jandrews
    '09 FourDubDee TRD OR
    If you want ride quality you're barking up the entirely wrong tree looking at spacers.
    Much better off with a 5100 kit from Toytec as Wolfpack suggested.
  3. Sep 4, 2011 at 1:08 PM
    Inacoma
    Inacoma [OP] Member
    thomas
    Western N.C
    07 DC TRD sport
    Thanks but looking for a spacer, not new shocks.
  4. Sep 4, 2011 at 1:11 PM
    Bloodhound
    Bloodhound Banned from the Pics Thread
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    For the price difference and a few other factors considered, like wolfpack mentioned, a set of 5100's up front would be the "best" alternative to a spacer lift.
    As far as the spacer kits that compress the coil vs. bolt on top of the coilover, If it were me, I would go over the top of the coilover to prevent any spring compression from happening. Low Range Off-Road makes a kit that Tundra guys seem to like on their trucks and a friend has one. Truth be told, it rides pretty much like stock and took about 3 hours to put on (using a lift though). http://www.lowrangeoffroad.com/inde...10-3-leveling-lift-kit-for-toyota-tacoma.html
  5. Sep 4, 2011 at 1:11 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Which spacer is better? Thats like saying which shit smells better :rofl:
  6. Sep 4, 2011 at 1:12 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The spacers that bolt to the top of the shock assembly will give you better ride. However, the shock can break off-road because the bump stop on the frame won't be contacted with the suspension in full compression.
  7. Sep 4, 2011 at 1:15 PM
    ColtsTRD
    Scott
    AZ
    This can happen if you even take a speed bump too hard lol
  8. Sep 4, 2011 at 1:15 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    The ones that go on top of the spring, compressing it will give you a terribly rough ride. Ones that go on top of the whole assembly cause your shocks to bottom out resulting in shocks that snap in half. Spend 5 more dollars and get the 5100's. They will give you 2.5" of lift and pretty much do the same thing as a spacer but do it better while giving you a better ride. For that extra 1/2" get a toytec top plate spacer.
  9. Sep 4, 2011 at 1:16 PM
    darkgreentaco
    darkgreentaco XXXL Member
    NorCaL
    Timberland Rocket
    King RR C/O's, Extra mustard, All-Pro expdtn Leaf, sesame seed bun, Icon UCA's Fox Resi's BAMFsliders, sweet candy coating, LCAskids, diffcover 17" Addicts Yukon 4.56 Mt/r kevlar
    Get both type of spacers.
  10. Sep 4, 2011 at 1:16 PM
    Bloodhound
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    That's the biggest thing I like about the Low-Range kit, they include new bump-stops.
  11. Sep 4, 2011 at 1:16 PM
    ColtsTRD
    Scott
    AZ
    and stack em!
  12. Sep 4, 2011 at 1:25 PM
    KenLyns
    Belly of the Beast
    Just went to the link you posted. Looks like a well-thought out kit.
  13. Sep 4, 2011 at 1:28 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Heres the top plate spacers
    And here are the preload spacers
    [​IMG][/IMG]
    your pick.
  14. Sep 4, 2011 at 4:36 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    listen to the advice being given to you.......
  15. Sep 4, 2011 at 4:53 PM
    AlphaEcho2k5
    AlphaEcho2k5 Well-Known Member
    Adam
    Hurlburt Field, FL
    '02 4Runner
    Damn, I can't save my $ fast enough to get rid of my pre-loads...
  16. Sep 4, 2011 at 5:08 PM
    jandrews
    Spacers will *not* give a better ride.
  17. Sep 4, 2011 at 5:13 PM
    705 Taco
    705 Taco Zombie Killer!
    Dean
    Barrie ON / St. Petersburg FL
    2016 TRD OR AC
    --Stock 2016. --------------------------------------------------------------------------------------------- 2011 had 6 inch ProComp lift, Eibach coils on 5100 Bilsteins at zero, 1/4 inch Toytec spacer on drivers side, rear TSB, 1.5 inch Deaver AAL, ProComp blocks and rear shocks, 8000 lb Warn winch on a Trans4mer grill guard, 33 inch BFG AT's, 18x9 XD Monsters, PIAA headlights, PIAA driving lights, Pyro's blue LED gauges, LED strip below tailgate, Armor Lid hard tonno, Hidden Hitch, Dee Zee bed mat, Tint, XM, Garmin GPS, Ultra Gauge
    A top spacer will do that^^^^^^. I ran a spacer until I installed my winch and they worked fine. The Eibachs/5100's do a better job supporting and controlling the added weight though. Bottom line is if I didn't add weight to my front bumper I would still be running spacers.
    And don't believe for a second that all those shocks broke hopping speed bumps.
  18. Sep 4, 2011 at 6:08 PM
    KenLyns
    Belly of the Beast
    A top plate spacer gives a better ride than than a coil spacer, since there's no additional spring preload. Ride with a top plate spacer should be about the same as stock.
  19. Sep 4, 2011 at 6:11 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    i have that kit for a first gen and love it. i dont offroad with my truck and just wanted a leveled look and for tire clearance
  20. Sep 4, 2011 at 6:14 PM
    705 Taco
    Dean
    2016 TRD OR AC
    Ya I didn't do enough research. The cost of my current setup and the spacer lift is pretty close so I wasted money on the spacers. I still stick to my previous statement: Properly installed spacers will be fine for on road and for the ocassional camping trip.
