Whine Noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by esMEECHO, Feb 28, 2024.
  1. Feb 28, 2024 at 3:00 PM
    esMEECHO
    esMEECHO [OP] Member
    Samantha
    2004 Tacoma 3.4
    Hi everyone! I have a 2004 Tacoma 3.4l
    On a cold start in the mornings there’s a whining noise for awhile
    Until it warms up and it kinda stops.
    But then it whines again when I’m turning and a little bit more when I accelerate while turning too.
    I checked my power steering fluid and it’s full.
    What can it be?
    Please help a lady out
  2. Feb 28, 2024 at 4:12 PM
    hp415
    hp415 Well-Known Member
    Paul
    1999 excab taco v6 TRD 5spd
    Sounds like your power steering pump may be getting tired. Should work fine enough and not cause any damage in the meantime.
    esMEECHO[OP] likes this.
  3. Feb 28, 2024 at 4:25 PM
    esMEECHO
    Samantha
    2004 Tacoma 3.4
    Bummer!! Any aftermarket brands you recommend? Or should I go OEM?
  4. Feb 29, 2024 at 12:00 PM
    hucklebarry
    hucklebarry Well-Known Member
    casey
    02 tacoma
    arb bumper, warn 8000 winch, arb air pump, arb front locker, and old man emu lift
    A lot of times you can flush the system. take the pump off clean the screens. then reassemble. Can be a messy process but will save you $$. If you don’t want to do that I would suggest fishing the system before replacing with oem.
  5. Feb 29, 2024 at 12:19 PM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    check your belts first before replacing PS pump
    b_r_o likes this.
  6. Feb 29, 2024 at 1:02 PM
    hp415
    Paul
  7. Feb 29, 2024 at 1:08 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    This. If the belt is loose it will slip and squeal when cold and while turning. Turningthe steering wheel makes the pump work harder so if the belt is loose it will slip
    When pumps begin to fail they usually groan and growl, not whine
  8. Feb 29, 2024 at 1:15 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Sounds like cavitation in the power steering pump.
    Take the reservoir off and clean the screen.
  9. Mar 1, 2024 at 8:41 AM
    esMEECHO
    Samantha
    2004 Tacoma 3.4
    Thank you everyone! Got a few options to try
  10. Mar 1, 2024 at 8:52 AM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    Definitely clean the screen. That will likely fix your problem. This video shows how to do it https://youtu.be/5k61KXRK8bM?si=1sXn9t9XJsVFM6lH
    If you do end up needing a new pump, and if the old pump is OEM, rebuild it. Aftermarket pumps are real hit and miss. Might only last a couple years. You can rebuild the original pretty easy. This thread, https://www.tacomaworld.com/threads/power-steering-pump-rebuild-how-to-with-photos.377002/ will show you how to do it.
    Here are links for rebuild kits.
    4 Cyl 2.7 3RZ rebuild kit: https://www.toyotapartsdeal.com/oem/toyota~gasket~kit~power~steering~pump~04446-04020.html
    6 Cyl 3.4 5VZ rebuild kit:https://www.toyotapartsdeal.com/oem/toyota~gasket~kit~power~steering~pump~04446-04010.html
