Whine when there's no pressure on the clutch
Discussion in '1st Gen. Tacomas (1995-2004)' started by 52Gravedigger52, Jul 6, 2020.
  1. Jul 6, 2020 at 9:12 PM
    52Gravedigger52
    52Gravedigger52 [OP] Active Member
    01 Tacoma
    I've got an 01 extra cab I haven't been nice to. Bought in 02 with 1500 miles. I'm its 2nd owner. Anyway after changing the clutch out the last time I noticed a whine when there's no pressure on the clutch. It will also roll down hill if you try and leave it in gear while parked. This is its 4th clutch (lots of mudding) never have had the flywheel turned or changed. Also noticed the bearing coming out of the trans in the bell housing seemed to be weak with a little play. Is it a combination of the flywheel or that no named bearing?
  2. Jul 7, 2020 at 1:41 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Most times it is the clutch release bearing that makes noise with no pressure on the pedal
    The pilot bearing should not be affected by pedal pressure but strange things happen.
    Your truck rolling down hill is a sign your compression is getting low besides that is what your parking brake is for.
    Black DOG Lila and cruiserguy like this.
  3. Jul 7, 2020 at 6:31 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard new member
  4. Jul 7, 2020 at 9:01 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    Gunna try hard get the clutch to 200k before the porkfest cometh
    :spending:
  5. Jul 7, 2020 at 12:09 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Don`t let anyone else drive your Truck you should make it.
    It only took 5 miles to cook a decent clutch
    High Noon likes this.
  6. Jul 7, 2020 at 12:27 PM
    eon_blue
    Azusa, CA
    Here in CA a dealership clutch job on a 1st gen goes for about 3 grand. Independent shops anywhere from $700 - 2000, varies quite a bit
    Ccrowe323 and High Noon like this.
  7. Jul 7, 2020 at 12:30 PM
    eon_blue
    Azusa, CA
    Forgot to say the 3 grand quote was from a dealership lol.
  8. Jul 7, 2020 at 12:30 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Trying to make enough to leave
    cruiserguy and High Noon like this.
  9. Jul 7, 2020 at 12:36 PM
    52Gravedigger52
    01 Tacoma
    Dealers are always high. Nissan wanted 3300 to do shocks and breaks on wifes Titan @ 3-4 days. I did it for $550 in 2.5 hrs. Got pre loaded struts. I've always done my own work on my toy for that reason.
    GQ7227 and eon_blue like this.
  10. Jul 7, 2020 at 2:12 PM
    52Gravedigger52
    01 Tacoma
    Wyoming09 is that the bearing on the transmission where the shaft comes out?
    cruiserguy likes this.
  11. Jul 7, 2020 at 2:26 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    nice! very nice!
    some aint so fortunate for whatever reason and gotta deal with the 'trained pros' and whatnot
    leaky top radiator hose was a piece of cake (but took ~3 hours) diy the dealer wanted $280, thats when i started scoffing and shaking the head
  12. Jul 7, 2020 at 2:32 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    there is a shifter gasket leak way up high top weeping tranny fluid (small so far) that will be fixed as well as rear main seal for good measure
    but also have 2 other nice sized upcoming jobs piled on top to keep er tipTop to budget out
  13. Jul 7, 2020 at 2:47 PM
    52Gravedigger52
    01 Tacoma
    We quit going to them all together because of that. The wife had taken to them religiously for oil changes, "safety" inspections, and even tires. When I went to take the driver rear tire off I couldn't get the lug off, just kept spinning. With some redneck ingenuity finally got it out. It was the wrong lug all together. Didn't fit the stud and was almost to wide to fit in the wheel. When I went in and tried to talk to them about it, they said "the tires have been on there for a year. Your problem not ours!" Thought I was gunna have to be escorted out lol
  14. Jul 7, 2020 at 9:10 PM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    My 1996 clutch replacement using new Borg-Warner (not re-manufactured) parts was right at $1000.
    I'd recommend staying away from re-man clutches.
  15. Jul 7, 2020 at 9:57 PM
    eon_blue
    Azusa, CA
    Me either... Sounds like remanufactured brake pads lol. I looked it up though and sure enough it's pretty common actually
  16. Jul 8, 2020 at 1:59 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    When you get into Heavy duty Truck parts Relined Brake Shoes were quite common .
    I knew a kid my age that worked for his dad they relined the Shoes for all the local cement haulers .
    Reman Clutch discs as well
  17. Jul 8, 2020 at 4:08 AM
    52Gravedigger52
    01 Tacoma
    Mine did the same thing for about 5 years in between 3rd and 4th clutch. When I changed the clutch out last time I used high temp gasket seal around the gasket. Hasn't leaked since and that was back in 2011.
  18. Jul 8, 2020 at 8:03 AM
    Kevin Jones
    Kevin
    Va
    Yes, I owned/operated a chain of auto parts stores for years and sold both new and re-manufactured clutch disc and pressures plates and reman outsells new by far, obviously because of price.
    Personally, I prefer NEW as defect rate is far less.
