Whiney Taco?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by The Traveler, Jun 19, 2012.
  1. Jun 19, 2012 at 11:54 AM
    The Traveler
    The Traveler [OP] Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Nope....no hidden superchargers...believe me I checked...twice.
    Since day 1 of taking delivery of my 2010 4x4 V6 (about 2 months ago) I've noticed it has a considerable amount of power steering whine to it. First thing I did was check the level, and it was low. I added some PS fluid I had at home, without realizing it takes ATF and not PS fluid. I only put in about an ounce, so I wasn't too worried.
    I took it back to CarMax within their 30 day warranty period to take care of a few TSB issues, and I mentioned this to them. They said it was normal, and the PS pump is functioning correctly and not leaking.
    Anybody else notice their pump? I have a Gibson cat-back and 33" BFG AT KO's, and I can hear it over those two, no problem. It seems to fluctuate with the RPM as well, obviously because it's a belt driven pump.
    Should I be worried? I've heard of people having luck using Lucas Oil PS Stop Leak to quiet down their pumps. Any insight on that?
    Thanks in advance guys! Wish it was a supercharger :(
  2. Jun 19, 2012 at 2:11 PM
    The Traveler
    SoCal
    I guess I'm the only one? :notsure:
  3. Jun 19, 2012 at 2:29 PM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    Nope. Mine is quiet and so is every other Taco I have heard. My old Pontiac was whiney as hell but so are all other GMs. Maybe you should take it to the dealer and get their opinion on it?
  4. Jun 19, 2012 at 2:30 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Tell your Taco to have a Coke and smile and quit it's bitchin and belly-achin :cool:
    On a more serious note, my PS pump is silent. Doesn't sound like normal operation to me...
  5. Jun 19, 2012 at 2:44 PM
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Icon extended travel coilovers and rear shocks, Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Timbren Bump stops ,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    I have a slight whine but it come from the a/c compressor and it goes away when the a/c is off. My power steering pump is quiet and I haven't heard anybody with that issue. I use to be a service writer years ago for a ford dealership and fords are known to have whinny power steering pumps and it is normal but that is a ford. Is you truck still under warranty? I would let them check it out and if they can't find the problem and later on something happens to the pump it is documented. Keep us posted and let us know how you make out.:)
  6. Jun 19, 2012 at 2:58 PM
    The Traveler
    SoCal
    Thanks for the info. Yeah I owned a Mustang and it sounded the same, but I wasn't worried because Fords are notorious for it. But I was a bit shocked to find out nobody else has this sound.
    Unfortunately, my truck is at 55,000 miles so the bumper to bumper warranty is done. Is this covered under the 60,000 mile powertrain warranty? If it is, I'll drop it off my Toyota dealer tomorrow.
