Whining sound from Engine
Discussion in '1st Gen. Tacomas (1995-2004)' started by MarksTac, Oct 20, 2009.
  1. Oct 20, 2009 at 6:24 PM
    MarksTac
    MarksTac [OP] New Member
    Mark
    Knoxville
    99 Tacoma Prerunner
    My truck is making a very loud whining sound when I raise the Idle (moving or not). I have searched online to find out what this is and gotten a hundred different possibilities. Any help on this would be greatly appreciated.
    Thanks!:confused:
  2. Oct 20, 2009 at 8:18 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    sounds to me like it may be a belt or a pulley.
  3. Oct 20, 2009 at 10:49 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Do you offroad much or drive in/around water or mud?
    The 3.4L A/C idler pulleys (bearings) tend to be the first to go...they get water in the bearings and start squeeking & will eventually stop working.
    Easy to replace. You can get an entire pulley replacement from the dealer for a decent price. If you just replace the bearings - make sure you get the proper bearings. Even though a bearing can & will fit -doesn't mean it'll handle the rpm's. Ask me how I know...:p
  4. Oct 22, 2009 at 8:53 PM
    tt01
    tt01 Active Member
    Canal Fulton Ohio
    01 tacoma 6" suspension lift
    35" tires, 15" wheels 6" suspension lift (fabtech),
    i have the same sound coming from my 2001 2.7L and i think it is the power steering pump going out
  5. Oct 22, 2009 at 8:58 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    I took my truck in yesterday for the exact some reason. I went through some mud & water and, like JANSTER said, mud got into my idler pulley. It got into my bearings and started wearing them out. Apparently the dealerships do not sell the bearings and only sell the idler pulley entirely so I had to purchase the entire thing. I had it installed and parts and labor cost me less than $100. Hope it works out for you.
    EDIT: I didnt get it installed at the dealership, rather by a mechanic
