Whistle in dash 2007
Discussion in 'Technical Chat' started by bossox9, Oct 22, 2007.
  1. Oct 22, 2007 at 1:35 PM
    bossox9
    bossox9 [OP] New Member
    Hello All:
    Brand new tacoma owner for about a week. Sorry if this has been posted before, but I did a search and did not find anything.
    I have a 2007 standard cab and when I am going 70+ I hear a high whistle comming from the dash. I have tried to roll down the windows and try different things with the air and still happens. It does not happen all the time but it is greater than 70%.
    Thanks
    Tony
  2. Oct 22, 2007 at 1:42 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    It's probably your windshield. Go ahead and try pressing on the windshield all around the edges to see if it changes pitch.
  3. Oct 25, 2007 at 10:22 AM
    TSUNAMI*22
    TSUNAMI*22 Obama can suck-it
    Stockton, CA
    '07 Standard Cab / White / 2.7 I4
    ScanGuage 2 equipped. Toyota DIY aftermarket Cruise Control mod
    There is a cabin-air filter in your glove box area that may not be installed correctly.
    Also, as the post above states, your windshield may not be sealed correctly. I would note whether the noise disappears when you are driving in the rain (seeping water may plug the whistle hole) If true...viola, you found it.
    Hope this helps.
  4. Oct 31, 2007 at 5:10 PM
    bbarian333
    bbarian333 Well-Known Member
    SoCal
    06, Accesss Cab, TRD Sport
    TRD exh, K&N drop in,TRD seat cvrs,tsb springs
    I've read about a fix for the noise your describing. You get the rubber stipping used to hold a household window sceen to the frame, (home depot) and push it into the open notch on the outside of your truck windsheild stripping. If you look at your windsheild stripping there is about a 1/8 th inch gap that this screen stripping will fit into . I've read that this will stop the noise.
  5. Nov 1, 2007 at 8:02 PM
    bossox9
    Thanks for the responses. I took it to the dealer and had it fixed. It was the windshield.
    I dropped it off at the dealer and got a 2007 Corolla as a loaner. It had 86 miles on it. I drove to work the next day just fine. I went to go to lunch and it did not start at all. I had to get a ride to the dealer to pick up my truck and the loaner had to be towed. They also told me this is the second time this has happened to this car. So far in two weeks I have had two 07 Toyotas and they both have had issues. :eek:
  6. Nov 1, 2007 at 9:19 PM
    morcheez
    morcheez Well-Known Member
    San Antonio
    05 XRunner BSP
    A BUNCH
    what did they do to fix it ? cuz mine does the same thing
  7. Nov 2, 2007 at 9:36 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    When my truck was at teh dealer they let me have an 07 Camry as a loaner. it had about 5k miles on it. One morning it was lightly raining and on the way to work i noticed the "anti-lock brake" light was on. i wondered if it was just a short or if the ABS was actually out. Obviously i needed to test this so slammed on brakes and they locked up and i just slid down the road. Then later that day when i left work for lunch the light was off and i slammed on the brakes and they worked fine. not very encouraging for a car with under 6k miles. Hopefully Toyota is not starting to slip...
  8. Nov 2, 2007 at 10:19 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    :laugh: I love it. "...Obviously i needed to test this..."
    Actually, I would have done the same thing. It is possible that the control module got some moisture in it and it shorted out temporarily. That happened on my old Acura Legend twice.
  9. Nov 2, 2007 at 10:30 AM
    nd
    Nate
    Greenville, SC
    That would be a serious design flaw considering that you need ABS the most in bad weather conditions. it really bothered me that something like that would go bad on such a new vehicle. the beamer was 17 years old and the ABS still worked great, i just assumed it was one of those bullet proof options considering how long it lasted on my old car
  10. Nov 2, 2007 at 10:55 AM
    sawdust
    sawdust Unapologetic Texan
    Frisco, TX
    07 TRD Offroad Radiant Red V6 Auto DC
    Homelink mirror, tailgate lock, 2ndary air filter removal, Access LE tonneau, Bugflector II, hitch-based bed extender, vent visors, suspension TSB, stall mat
    I gotta laugh, but I sure am glad I don't drive on the same roads as you do.
  11. Nov 2, 2007 at 12:37 PM
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    Yeah I know a BUNCH of dealers use vehicles that have been wrecked and repaired for "loaners". That may have been one of them. :eek:
    I drove a Oldsmobile Intrigue that kept loosing the ABS randomly. It would get cold and the contacts for the power wouldn't connect. :der:
    Just be glad that you didn't really need it! :thumbsup:
  12. Nov 2, 2007 at 12:50 PM
    nd
    Nate
    Greenville, SC
    Do you know a better way to test if the ABS works? cause i sure dont. plus it wasn't my car or tires so i didnt care
  13. Nov 2, 2007 at 3:44 PM
    sawdust
    Frisco, TX
    Yeah, so why care if the ABS works? It's not your car.
  14. Nov 5, 2007 at 9:48 AM
    nd
    Nate
    Greenville, SC
    Curiosity killed the idiot... Actually, i felt that i needed to know if it was funcitoning in case i caught myself in a "need to stop fast" situation. If it wasn't working i needed to know so i could pump the brake and not just slam it like i would if i knew i had abs. In reality i just wanted to see if i could make the car skid down the road.... and i could :)
  15. Nov 5, 2007 at 9:55 AM
    Big Guns
    Big Guns Well-Known Member
    Temecula, CA
    07 PreRunner SR5 4.0L Indigo Blue
    Aero Turbine 2525 exhaust, Black Headlight Mod, DO Rock Sliders
    I have the same whislte problem. Was it a quick fix at the dealer or was it out some time? I really cant afford my truck to be gone for very long due to school and work. I guess i can try the weatherstriping thing...
  16. Nov 5, 2007 at 12:58 PM
    sawdust
    Frisco, TX
    The truth comes out! That's precisely why I said I'm glad I don't drive on the same roads as you. With my luck I'd have been the guy right behind you when your brain cell wandered between noticing the ABS light was on and wanting to skid the car.
  17. Nov 18, 2007 at 4:24 AM
    vivafire
    vivafire Well-Known Member
    Galveston,Texas
    07 PreRunner SR5 V6
    Add N-Fab side steps-debaged,cat-back exhaust from MagnaFlow and a Stage 2 intake system from AFE
    My does the same thing so I'm going try the stipping first ,cause I don't want to lose my new truck smell just yet.
