White/gray film under oil fill cap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ph16drive, Dec 5, 2008.
  1. Dec 5, 2008 at 1:01 PM
    ph16drive
    ph16drive [OP] \m/.....\m/
    Paul
    Clevelandish
    08 DC, V6, 4x4, 5-Speed Auto
    Shorty antenna, Pop-&-Lock tailgate lock, Undercover bed cover, Aeroforce Interceptor gauge (custom mount), bed mat, AFE Pro Dry S air filter, map light mod, suspension TSB, Billy 5100's all around, Eibach springs, custom fuel tank armor plate, custom cat armor plate, painted front brake calipers, Grillcraft MX upper grill & Hella 500s, ipod adapter, dash pushbutton garage door opener, aux reverse lights, custom ipod nano 4G mount, seatbelt chime mod, custom bull bar w/ (3) Lightforce 140 Lance lights, POR-15 Chassis Coat Black drivetrain, illum 4x4 switch, xtra bed D-rings mod, locker anytime mod, diff breather relocation mod, ABS disable switch mod, Heated seats
    Today, i noticed a white/gray film under the oil fill cap (08 V6 @ 10,500 mi). Photo attached; if you look in the background, you can see a little of the fill neck. When looking thru the fill neck, the engine is clean and appears normal - no white/gray film. The oil dip stick is also normal. I called the dealer and was told that it is most likely because of condensation due to the recent weather (40° and rainy a day ago and 23° today). I use Castrol 5W-30 conventional oil and a toyota filter every 3000 miles.
    What do you guys think? Has anyone else seen this? Do I have anything to worry about? I cleaned the cap and will keep an eye on it as I'm about 500 miles away from an oil change.
    Thanks for your input.
  2. Dec 5, 2008 at 1:14 PM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
    I found it on mine too, I chalked it up a little condensation mixed in with oil that found its way onto the cap
  3. Dec 5, 2008 at 1:17 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    thats what it is....nothing to worry about.:)
  4. Dec 5, 2008 at 1:44 PM
    ph16drive
    Paul
    Clevelandish
    Thanks guys.
  5. Dec 20, 2008 at 2:18 PM
    Johnny_knox69
    Johnny_knox69 Well-Known Member
    Same here white oil (oil/water) under cap.
    Never been there before.
    Runs worse then ever. SO i think....
    The lifters are making more noise now too. This concerns me, because if there is something wrong with the oil, which there must be, then the lifters would be one of the first to show issues......???????????????
    After I changed the oil the lifters sounded much better?????? damn
    Any more ideas?
  6. Dec 20, 2008 at 3:07 PM
    stro1965
    stro1965 Well-Known Member
    Bellevue, NE
    09 Timberland Mica Tacoma 4x4
  7. Dec 20, 2008 at 3:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    No lifters in DOHC engines. The noise is the valve buckets. They are adjusted via shims (shim under bucket). They will always have a ticking sound, but oil will definatly play a role to how loud they get. Try switching to a good synthetic oil, and see if that helps.
  8. Dec 20, 2008 at 4:37 PM
    Johnny_knox69
    I am using Mobil 1 now. They got quieter when i changed the oil. But are getting louder and I am seeing more of the white stuff.
    I never had the white stuff before...........I checked the coolant, nothing, and it appears to be same level as before
    I tow a 4000# travel trailer 10k year.
    Toy said the same thing about the noise.....I wasn't sure. It is not quiet a deisal sounding motor but getting there!! lol
  9. Dec 20, 2008 at 4:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What year is your truck? Engine?
  10. Dec 20, 2008 at 7:36 PM
    Johnny_knox69
    05 48k miles
  11. Dec 20, 2008 at 10:24 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Me 3 on 2006 V6 auto 24k running mobil 1
  12. Dec 21, 2008 at 6:34 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Never see it on mine.
  13. Dec 21, 2008 at 6:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good point. :)
    Upon further investigation into this, it seems there are a couple of reasons why this is happening to peoples trucks.
    As the oil fill tube is plastic and long (unlike the ones that dump the oil right into the head with no fill tube), the water in the air is going to condens in it first. And combined with short trips that dont give the engine oil time to "burn off" the water, it can creat this stuff on the bottom of the filler cap. Seems there HAVE been some problems associated with this, but I have only found them to be on Dodge 4.7 engines. Every other vehicle manufacture has this issue, and only in states that have regular humidity, Like Oxymar00n mentioned. It seems to be no issue if regular oil changes are performed. Audi and BMW owners are finding the same issues with their vehiclesw, and their solution is to shorten their oil change intervals (they were doing 25,000 Km intervals, but I cant find what they are going to). If you have a 5000 mile oil change, shorten it up by 1000 miles. For those that change at 3000 miles, try shortening it 500 miles or so until you no longer see the problem in the oil cap. OR, try to take longer drives. :)
  14. Feb 18, 2009 at 6:47 AM
    TacomaTRD08
    TacomaTRD08 Member
    Palmer, MA
    08 TRD Sport
    westin bull bar, westin off road lights, K&N filter, Gibson stainless steel sweptside cat back exhaust, toyo open country A/T's, genisis trifold tonneau cover
    i have this too. 08 with 13,500 on it. always ran castol syntec and a toyota filter. my issue is my coolant overflow is also empty. anyone else have that problem?
  15. Feb 18, 2009 at 7:04 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    Stock for now
    I just went & checked my overflow, its been sitting all night & there is only a very small amount in the bottom. Toyota has just serviced it a couple months ago & temp on my scangauge reads 184-186 warmed up good.
    I still have residue on the cap too but feel its how the chris, SS, & krootz described it. I run syn, toy filter, 28k on the 2006 odo & live in VT. Not sure if this helps or not.
  16. Feb 18, 2009 at 9:36 AM
    Johnny_knox69
    Mine was very thick oil/water mix in my cap and down in the riser.......... I noticed my cap did not completely seat on the riser. I tried to put in on with out cross threading it, after about 5 tries it finally seated properly.................Can't completely tell if this fixed it since I am out of town now and can't check it in real world use. But around the house for week it was completely corrected.............So go find out if it is a toy manufacturing issue and let me know.....
