White wheels for 2nd gen
Discussion in 'Wheels & Tires' started by chewy3384, Jan 16, 2012.
  1. Jan 16, 2012 at 8:10 AM
    chewy3384
    chewy3384 [OP] Professional ball dropper.
    Keith
    Southern Maryland
    Hey guys. Has anyone been able to run this type of wheel?
    Here are the specs:
    Brand-U.S. Wheel
    Manufacturer's Part Number-70-7860
    Part Type-Wheels
    Product Line-U.S. Wheel 70 Series White 8-Spoke Wheels
    Summit Racing Part Number-USW-70-7860
    Wheel Diameter-16 in.
    Wheel Width (in)-8.000 in.
    Wheel Material-Steel
    Primary Wheel Color-White
    Wheel Finish-Gloss
    Manufacturers Wheel Series-U.S. Wheel 70 Series
    Backspacing (in)4.500 in.Offset-0.00mm
    Wheel Construction-2-piece
    Beadlock Functional-No
    Beadlock Included-No
    Lug Nut Seat Style-Conical seat - 60 degree
    Hub Centric-No
    Center Bore Diameter (in)-4.280 in.
    Center Bore Diameter (mm)-108.71mm
    Center Cap Included-No
    Load Rating (lbs)-2,000 lbs.
    Valve Stems Included-No
    Quantity-Sold individually.
    Wheel Bolt Pattern-6 x 5 1/2 in.
    I'd love to run this bad ass old school look on my SW DCSB. What do you guys think about fitment? My searches haven't produced much.
  2. Jan 16, 2012 at 8:14 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If you find the right wheel specs, I don't see why they wouldn't work. I don't know about white wheels on a white truck though... I'd have to see it I guess.
  3. Jan 16, 2012 at 8:34 AM
    chewy3384
    Keith
    Southern Maryland
    I only ask because i've read alot about people rubbing their calipers with 16" steel wheels. By the numbers, I think these should fit. And I normally wouldn't go with white on white, but with these older style wheels, I think it could work well.
  4. Jan 16, 2012 at 8:37 AM
    Pugga
    Massachusetts
    As far as I know, 16's aren't a problem if you get the correct backspacing. I think there was only 1 particular type of 16" wheel people were having issues with. 15's take some grinding on the caliper or a wheel spacer.
    Wait for KPT, he knows his stuff about this sort of thing. :cool:
  5. Jan 16, 2012 at 8:42 AM
    Oat
    Oat Well-Known Member
    Florida
    2001 Prerunner
    Gibson Exhaust, Painted factory steel wheels, Chrome wheel caps, K&N Air intake, Tint, Regular Bilstein (yellow/blue) all around, Leveling spacer kit upfront, Partially de-badged, Westin Bullbar with skidplate, White, Double Cab Prerunner SR5
    They would get dirty....real fast.
  6. Jan 16, 2012 at 8:43 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    It is usually steel wheels that have the issues with rubbing in 16's. Is there any way you could get a shop to order you those and let you test-fit them?
    And btw I completely approve of this thread :rockband:
  7. Jan 16, 2012 at 8:45 AM
    TexasTacoma37
    This even looks real good IMO, props for being different.
  8. Jan 16, 2012 at 10:25 AM
    chewy3384
    Keith
    Southern Maryland
    Thanks for the info guys! In theory, even if they rub the calipers, I could use the 1/4" spacers from wheelers to give me some clearance right?
  9. Jan 16, 2012 at 10:27 AM
    TexasTacoma37
    Sometimes that works, sometimes it doesn't.
  10. Jan 16, 2012 at 10:27 AM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Don't 2nd gens need hubcentric specific wheels?
  11. Jan 16, 2012 at 10:29 AM
    TexasTacoma37
    They do not. The oem wheels are hubcentric, yes. But you can buy lug-centric wheels and use extended-thread lug nuts to center the wheel.
  12. Jan 16, 2012 at 10:42 AM
    chewy3384
    Keith
    Southern Maryland
    Doesn't work....like not enough threads for the lugnut to bite? Or they just aren't quality spacers?
  13. Jan 16, 2012 at 10:43 AM
    TexasTacoma37
    Doesn't work as in the wheel still hit the caliper.
  14. Jan 16, 2012 at 10:52 AM
    chewy3384
    Keith
    Southern Maryland
    I gotcha. Thanks a bunch for the help KPT! I might just pick one up and see how it goes. They arent that expensive.
  15. Jan 16, 2012 at 10:56 AM
    Manwithoutaplan
    ID
    i would rock it :D old school style :D
  16. Jan 16, 2012 at 2:16 PM
    MattsTruck
    MattsTruck Member
    Cincinnati
    Black TRD Off Road
    ULK, Total Chaos UCAs, Shrockworks front bumper
    Those are great!
  17. Oct 22, 2012 at 6:14 PM
    speedydave
    speedydave Well-Known Member
    Dave
    Hickory, Nc
    Mustang GT
    I know this is an old thread, but I just picked up a set of stock steelies, and I was thinking of painting them white to match my truck.Have any more pics?
  18. Mar 9, 2013 at 4:18 PM
    FuzzHead
    FuzzHead Member
    Jarrod
    South Dakota
    '05 4x4 Reg Cab
    Bilstein 5100 all around set @ 1.75; smoked OEM fog lights; smoked Wade hood protector; OEM large storage box; cruise control; OEM intermittent wipers; 304 double-walled stainless exhaust tip; Sirius StarMate with FM direct adapter; front mud flaps removed; Minnesota Wild license plate holder
    bump to see if Chewy test fitted one.
  19. Mar 11, 2013 at 5:27 AM
    chewy3384
    Keith
    Southern Maryland
    Sorry, I never did try them out. Funds is tight right meow.:(
  20. Apr 1, 2013 at 2:43 AM
    nelztaco
    nelztaco Well-Known Member
    Neil
    Levittown, PA
    09 TRD Sport DCLB 4x4 SW
    UNDERCOVER, EIBACH COILS, TSB 4 LEAFS, TRD WHEELS, 255/85R16 KM2
    Now that I've done the black wheel thing, i think i'd like to try white. Maybe some fj steelies like another member I saw on here or maybe old tundra wheels pc'd white.
