Whitney Houston
Discussion in '2nd Gen. Builds (2005-2015)' started by Phil Dammit, Jun 28, 2012.
  1. Jun 28, 2012 at 1:08 PM
    Phil Dammit
    Phil Dammit [OP] Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Bought this little gem back in 07 for 8500 bucks. Single cab, salvage title, 2tr-fe 5lug.
    A year later I moved to Va to stay with my grandparents/take care of them for a summer and crafted some lift spacers since nothing had come out and I was poor.
    How she is today
  2. Jun 28, 2012 at 1:11 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Fabricates his own lift from a block of metal.... Uses emergency jack to install :thumbsup: Impressive sir
  3. Jun 28, 2012 at 1:14 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Then I went at the interior dont even have a photo of my first install which was two memphis amps and two tens all carpeted and done out of MDF. Looked alright, hit good, sounded good but took up way too much space so I went and did this.
    Welded up an amp rack that bolted to the main support, Memphis 75x4, 50x4, and mono class d good to 1100@ 1. 75 was bridged and ran the mid basses, 50 was bridged and ran the tweets. For the older polk is sounded alright and I was again, broke as a joke so no sub for a couple years.
  4. Jun 28, 2012 at 1:15 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Ejack and fist of furry to compress springs to install :cool: Left all my auto tools in Phoenix on that trip. Never doing that again.:(
  5. Jun 28, 2012 at 1:16 PM
    Sunner
    Sunner Well-Known Member
    Wow that's gotta ride like hell doesnt it?
  6. Jun 28, 2012 at 1:17 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Finally got a tax return worth a damn and spent it on an Eclipse AVn suggest by Dave over on CT a few years back. Best investment ever. AVN6600 only suck is that it came with a super outdated map disk.
  7. Jun 28, 2012 at 1:18 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    For a daily its fine, shes seen the dezz a few times but nothing extreme. I was going to eventually save up and LT her but a single cab and a 2tr-fe just dont cut it as a combo.
  8. Jun 28, 2012 at 1:19 PM
    Lightningtodd
    Lightningtodd Well-Known Member
    Todd
    Albuquerque
    2010 Double Cab 4x4 TRD Off Road
    Impressive spacer fab! How does it ride?
  9. Jun 28, 2012 at 1:20 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Scored a set of 200SX seats for 100 bucks over at a local pic 'n' pull. Swapped sensor and harnesses. Bought an extra set of bucket mounts and built custom buckets. Sensors and airbag work. When I was extracting the inner bolt for mock up the damn inner nut snapped off so I had to reweld that to the body. Other than that they are great.
  10. Jun 28, 2012 at 1:23 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Im pretty sure there are a few LT 4cy guys on TW :D
    Your truck is looking good.
  11. Jun 28, 2012 at 1:23 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    As good as a spacer lift can ride. Stock bounce with added lift. Got way better when I did the lower control arm bushings.
    Yes their are but I want to be able accelerate without haveing to downshift two gears. Im on 32's now.... can only imagine on 33x12.5's....:(
  12. Jun 28, 2012 at 1:26 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Picked up an indy hurst shifter for 50 bucks at the same yard a week later, went ahead and fab'd that in. Other than the tranny whine in 5th its legit:cool:
  13. Jun 28, 2012 at 1:28 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    Regear?
  14. Jun 28, 2012 at 1:29 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Well daddy made good money a year ago so he reinvested in whitney, bought her new wheels and tires, BHLM her front, got her tinted, and redid the grill insert so here she is now with a photo in comparison to a 6lug. She sits about 3/4" higher now that I redid the LCA bushings.
  15. Jun 28, 2012 at 1:30 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    That is a solution yes, but Im tired of a regular cab, want enough room to cram someone else in the back for downhill/snowboard trips.
  16. Jun 28, 2012 at 1:34 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Invested in some exhaust material, muffler, and cat. Highflow cat, magna muffler 2.25 in and out, aluminzed pipe with some U bends since I dont have access to a bender. SUCK This is what ended up happening. Get he same milleage and same performance but it sure does sound cooler. Also installed the URD sim to kill the light.
  17. Jun 28, 2012 at 1:37 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    After 120k miles the clutch finally went out so I went ahead and pulled that out in the garage and pop'd it back in. tractor whine went away with the new throwout bearing. Intersting that the OEM throwout was so noisey yet an aftermarket replacement is not.....:eek:
  18. Jun 28, 2012 at 1:41 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Did a snowboard rack for shits and grins. Locks go on the bed rails so they cant steal the racks while Im shredding and the racks themselves lock so people cant steal my board while Im not with my truck.
  19. Jun 28, 2012 at 1:43 PM
    Aw9d
    Aw9d That one guy
    Az
    Looking good! :thumbsup:
  20. Jun 28, 2012 at 1:45 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Thanks but, she's maxed out for my taste, been cruising list for X's as of late. Gonna get her top repainted and then hopefully sell for 7500-8k and buy an X. Its time for a bigger motor and some more cab space.
