Whitney Houston
Discussion in '2nd Gen. Builds (2005-2015)' started by Phil Dammit, Jun 28, 2012.
  1. Dec 27, 2013 at 9:48 AM
    #81
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    never have problem with them coming loose under speed or anything?
    #81
  2. Dec 27, 2013 at 9:50 AM
    #82
    Phil Dammit
    Phil Dammit [OP] Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    No, why would you think they would?
  3. Dec 27, 2013 at 9:53 AM
    #83
    richardbui23
    Richard
    Arlington Texas
    Stacy
    #83
  4. Dec 27, 2013 at 9:55 AM
    #84
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Those are sexy, are your lugs backing off or are the studs snapping? One is due to not torquing them enough the other would be fatigue and over torquing.
  5. Dec 27, 2013 at 9:57 AM
    #85
    richardbui23
    Richard
    Arlington Texas
    Stacy
    2 studs snapped off and the one last week backed off. bout to just replace all the studs and lug nuts
  6. Dec 27, 2013 at 10:06 AM
    #86
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Your studs are pressed in so I dont know how it backed off. I have replaced two since i have had the truck. I got them both at O'Reilly for cheap.
  7. Dec 27, 2013 at 10:08 AM
    #87
    richardbui23
    Richard
    Arlington Texas
    Stacy
    no i mean 2 studs snapped off and 1 lug nut backed off. should i just replace them all or is it one of those parts that should be replaced only if it breaks?
  8. Dec 27, 2013 at 10:16 AM
    #88
    Phil Dammit
    Your Mom
    Tempe, Arizona
    If it aint broke done fix it. I only replaced the ones that failed. Depends on how you look at the repair. Truly it is personal preference.
  9. Dec 27, 2013 at 10:17 AM
    #89
    richardbui23
    Richard
    Arlington Texas
    Stacy
    gotcha :thumbsup: thanks for the help bud
  10. Dec 27, 2013 at 10:27 AM
    #90
    Phil Dammit
    Your Mom
    Tempe, Arizona
    anytime Churd
  11. Dec 28, 2013 at 12:23 AM
    #91
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab / 12 4x4 double cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    Can't wait to see! Take plenty pics broseph. One day ill get them and ask you a million questions about ur settings ha ha ;p
  12. Dec 28, 2013 at 6:16 PM
    #92
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Lol, got the dif apart, and ready to slap in to find out dude gave me the wrong bearings and shims when he sold it to me. And what do you know they were special order, and camelback only had 1...... :(
  13. Dec 29, 2013 at 7:49 AM
    #93
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Yeah it does nut I did replace the rack boot on the passenger side and secured the ebrake line so it doesn rub the shaft anymore
  14. Jan 4, 2014 at 10:25 AM
    #94
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Whitney got LSD bitches! Toyota trd for 80 bucks + 90 bucks worth of bearings
  15. Jan 4, 2014 at 11:36 AM
    #95
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Nope, but she chirps sounds uneven corners :)
  16. Jan 4, 2014 at 10:23 PM
    #96
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    :woot: That's a beefy Hino LSD.
  17. Jan 5, 2014 at 9:15 AM
    #97
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Its a srock Trd LSD out of a 6lug
  18. Jan 5, 2014 at 10:38 AM
    #98
    KenLyns
    Belly of the Beast
    Which is borrowed from Hino, yes.
  19. Jan 5, 2014 at 11:22 AM
    #99
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Hmmmm, did not know hino was supplying the lsd for Toyota. Sweet
  20. Jan 5, 2014 at 11:35 AM
    #100
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Also got some fogs
