Who adds weight to their truck for winter driving?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cvd2312, Nov 14, 2011.
  1. Nov 14, 2011 at 3:14 PM
    Cvd2312
    Cvd2312 [OP] Well-Known Member
    Cory
    Oregon
    2013 DCSB TRD OR
    OME 885’s w/NitroCharger’s 3rd Gen Leaf Pack w/Icon Progressive AAL 265/70/17 Falken Wildpeak’s 17x9 Raceline Defender Wheels
    Who on here adds weight (sand bags, ect) in the back of their truck for winter driving? Does anyone have a recommendation on a good amount to add?
  2. Nov 14, 2011 at 3:15 PM
    YotaMark
    YotaMark Well-Known Member
    Mark
    Mentor, Ohio
    08 Tacoma 4 cyl 5 speed 4X4
    Rear Gate security Mod (although I seldom take my eyes off it) "Harsh Ride" Shocks and Springs TSB performed by "Me" New Cooper Discoverer AT3s 265/75R16s (fit well) Front "Tacoma Mike" light mod! Rugged Ridge floor mats. Bought another set of D rings and installed them in my wheel well. Perfect! Just hit the big 6000 Miles 12/19/11, Installed an alarm system to go with my factory power door locks 1/21/12
    Im adding a few sand tubes. OBTW. Did you see the rolled over first gen Tacoma on the news this morning? It was in Denver.... showed it being rolled back on its wheels.
  3. Nov 14, 2011 at 3:21 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
  4. Nov 14, 2011 at 3:25 PM
    Battle Pope
    Battle Pope Christ-a-licious
    Korben
    Class 6
    Automatic 5 Lug
    squash air freshner
    im buying bags of kitty litter, good to use as traction if I get stuck.
  5. Nov 14, 2011 at 3:26 PM
    acad54
    acad54 Well-Known Member
    North East Missouri
    2016 Tacoma TRDOR
    I have five 60 lb bags in mine
  6. Nov 14, 2011 at 3:32 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    When it snows or we have an ice storm 5 50lb sand bags are over my rear axle in the bed, but i'm 2wd. Amazing difference.
  7. Nov 14, 2011 at 3:38 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I usually throw a couple hundred pounds in the bed. This year probably not this year though because of the shell.
  8. Nov 14, 2011 at 3:44 PM
    palmxp3
    palmxp3 Active Member
    Philadelphia
    2002 AC TRD OR V6 4x4 Tacoma
    This will bey first winter with the Taco, is adding weight in the back still recommended if you're 4x4?
  9. Nov 14, 2011 at 3:44 PM
    tacotrd647
    tacotrd647 Resident "dude"
    Caleb
    Ridgeway, Iowa
    02 Prerunner SR5 TRD
    KMC Enduro Wheels, 265/75/16 toyo open country at2
    I fill the bed of the truck with snow. Worked very well over the years!:D
  10. Nov 14, 2011 at 3:46 PM
    Jester243
    Dan
    Spokane, WA
    wouldn't hurt to add the weight.
  11. Nov 14, 2011 at 4:19 PM
    Madjik_Man
    Colorado Front Range
    I add a 40 lbs bag of cat litter only when I trek up into the mountains in wintry conditions.
    I place the bag in the center of the bed, directly in front of the rear axle.
  12. Nov 14, 2011 at 5:28 PM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    Will you be driving locked in 4 wheel all winter ????
    Tacomas LOVE to come around 180/270 on fresh POWDA ;) :cool:....especially if you are "dog" tired after plowing all dam night....
    boss tells you to go get 40 winks and you FORGET to "lock it in"....
    That 7 second bull ride you always here about....:rolleyes: ;)... try spinning your Tacoma 1/2 asleep.....that same RUSH....
    PUT SOME DAM WEIGHT OVER THE REAR and go have FUN !!!!!!!
  13. Nov 14, 2011 at 5:35 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I have the weight of a shell and use a couple bags of sand over the axle.
  14. Nov 14, 2011 at 6:47 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    X2.
  15. Nov 14, 2011 at 6:50 PM
    Irish020
    Irish020 Well-Known Member
    Phil
    Pennsylvania
    '05 Tacoma TRD Sport 4 Door Longbed
    ARE Hard Tonneau Cover Flowmaster American Thunder Super 50 Series Stainless Dual Exhaust Toytec Ultimate 3" w/ UCA's
    Sandbags......
  16. Nov 14, 2011 at 6:52 PM
    jobrien
    jobrien shit happens then you die
    Josh
    Ontario California
    2011 single cab base 4x4
    Bed mat, cleats, scangauge, new headlight bulbs, weather techs, more to come
    Same here 95% of the time it works every time
  17. Nov 14, 2011 at 7:50 PM
    99yodataco
    99yodataco Little Taco that could
    Chad
    New Mexico, it's just a little bit fresher.
    MGM 21 TRD OR 6sp MT
    Soon...
    I throw on my topper back on. Also acts as a dry storage area, as well as adding weight over the wheels.
  18. Nov 14, 2011 at 8:02 PM
    Bloodhound
    Bloodhound Banned from the Pics Thread
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    Plus it keeps your beer cold for after plowing, snow-blowing and shoveling:rolleyes:
  19. Nov 14, 2011 at 8:10 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    I added 3 60lb sandbags between the wheel well plus I had the cap with my 97 xtra 4x4 (RIP) and she handled pretty well last winter. but this will b the first winter with the new truck and I plan on adding the same weight. we'l see how it does...
  20. Nov 14, 2011 at 8:31 PM
    Madjik_Man
    I don't understand why you all add so much weight
    200...300 pounds?
    I've used 40 lbs (plus about another 40 in gear) for over a decade and it works absolutely just fine
