Who doesn't use a torque wrench?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trapperr, Feb 15, 2016.
  1. Feb 15, 2016 at 9:16 AM
    Trapperr
    Trapperr [OP] Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    I'm piecing together last minute tools for a couple of bigger jobs on my tacoma. One is my t belt, water pump job. The other is installing my OME lift, tie rods, and ball joints. The one piece of equipment I am lacking is a torque wrench. I want one to go up to 200ft/lbs but they are pricey.
    For these 2 jobs, is a torque wrench a necessity? Of all the work I have done on my vehicles, I have never used a torque wrench. Not once.
  2. Feb 15, 2016 at 9:18 AM
    TN_Tacoma
    TN_Tacoma Well-Known Member
    David
    New Jersey
    07 Taco PreRunner SR5 DCSB
    K&N CAI, MBRP Cat-Back Exhaust, 265-75-16s Nitto Terra Grappler, Tuff A.T. 15s 16 inch wheels, 1.25" wheel spacers, black bumper, bumper light bar in grill, CB radio, Aftermarket speakers and 2 10 inch subs, LED odometer mod
    When doing anything with a lift, tie rods and ball joints I'd say a torque wrench is a necessity
  3. Feb 15, 2016 at 9:20 AM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    invest in one...it's safer for all the work you do on vehicles
    JimboAnz and DrFunker like this.
  4. Feb 15, 2016 at 9:20 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    TheSpeediTurtle likes this.
  5. Feb 15, 2016 at 9:21 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Lol, you've been installing wheels without torquing the lugnuts?
  6. Feb 15, 2016 at 9:23 AM
    la0d0g
    running for the hills
    For crawling not hauling
    I use a torque wrench for everything on my truck. Yes, even the lug nuts.
    JimboAnz likes this.
  7. Feb 15, 2016 at 9:24 AM
    TacomaZL
    TacomaZL Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
    I've been torquing lug nuts without a Torque wrench for a while, just recently got a cheap one from HF....holy sh$t did I over torque those things.
    Get one, even a cheap one. It's better than nothing for basic things.
  8. Feb 15, 2016 at 9:24 AM
    Connormc11
    Connormc11 Jangler
    Connor
    Norfolk VA
    2010 DCSB TRD-Offroad
    "Cross-threaded or torqued to Spec... tight is tight"
    but for real a torque wrench is worth it.
  9. Feb 15, 2016 at 9:24 AM
    Trapperr
    Reno, NV
  10. Feb 15, 2016 at 9:26 AM
    NMW 4x4
    NMW 4x4 Wheels With Moose.
    Walt
    T8 R11 WELS, Maine
    '14 DCLB SR5 4x4
    You definitely want a torque wrench for lift installation. I went without one for years, and now have a strong appreciation for them. If nothing else, they provide you with a good piece of mind knowing everything is as tight as it's supposed to be.
    But, also; for the safety of you, your passengers, and everyone you share the road with, you should properly torque your bolts.
    Edit: Didn't catch your most recent post ^. Good choice! :thumbsup:
  11. Feb 15, 2016 at 9:26 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
  12. Feb 15, 2016 at 9:30 AM
    KenLyns
    Belly of the Beast
    The timing belt's challenge would be to have another long-handled tool to hold the crank pulley stationary while you loosen/tighten the pulley bolt.
    With tie rod ends, the stud may start spinning while you try to loosen/tighten the nut. I used a 1/2" electric impact for this.
  13. Feb 15, 2016 at 9:41 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    I usually just crank on them til the bolt breaks then back off half a turn.
  14. Feb 15, 2016 at 9:47 AM
    Trapperr
    Reno, NV
    I've been installing EVERYTHING without a torque wrench
  15. Feb 15, 2016 at 9:50 AM
    KenLyns
    Belly of the Beast
    ^I tighten most frame bolts and drain plugs without a torque wrench. Lugnuts in particular need to be torqued to spec, because the wheel's motion puts a loosening torque on the lugnuts by inertia.
  16. Feb 15, 2016 at 9:58 AM
    Pushincaskets
    Pushincaskets Well-Known Member
    High Point, NC
    07 PreRunner DCSB
    4" Maxtrac Spindles, Dakars and extra leaf, SOS Concepts bed rack, Lund tonneau cover, RTT,
    HUH?? So if that was the case it would only loosen one side of the truck correct. LOL
  17. Feb 15, 2016 at 9:59 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Whats the rating on lug nuts anyhow?
  18. Feb 15, 2016 at 10:23 AM
    KenLyns
    Belly of the Beast
    ^83 ft-lb
    Yes. In some race cars, they use LH thread lug nuts or hub nuts on one side of the car for this reason. Usually the LH thread nuts are color-coded to avoid confusion.
  19. Feb 15, 2016 at 12:34 PM
    Indy
    Indy Master of all I survey.
    Old vehicles, left handed threads on 1 side was the norm. I believe my willys is set that way. They had an obvious concern that the near light speed, 60mph, would undo the lugs :laugh:
  20. Feb 15, 2016 at 12:37 PM
    ragincajun35
    ragincajun35 Well-Known Member
    Spencer
    Louisiana
    2015 DCSB MG TRD Offroad
    See Builds....
