Who has good ears and a good idea
Discussion in 'Suspension' started by Mitch, Apr 15, 2014.
  1. Apr 19, 2014 at 5:23 PM
    Mitch
    Mitch [OP] Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    I like that idea. I'll try it
  2. Apr 20, 2014 at 12:59 PM
    Mitch
    Mitch
    Spokane, WA
    I let the truck sit for 2 days. Sound is still there. So I'll look to add more grease to the lower ball joint and see if that helps. By piercing the ball joint am I risking a possible future failure?
  3. Apr 24, 2014 at 10:40 AM
    Mitch
    Mitch
    Spokane, WA
    Took the shocks off today to see if I could figure out what this sound was. Well I unbolted them and cycled the suspension to figure out if it was a bushing, ball joint or the shock. Passenger side was all clear. No noise. Which I haven't ever heard anything over there. So that is good.
    Drivers side though is the problem. And the problem is the UCA bushings. I am going to go loosen the bolt and re-torque
  4. Apr 24, 2014 at 2:35 PM
    Mitch
    Mitch
    Spokane, WA
    Here's the video. The coilover is just resting on the CV boot. Only the UCA, spindle and LCA are connected
    http://youtu.be/9Esy0Z-QKRg
  5. Apr 27, 2014 at 2:59 AM
    splitbolt
    splitbolt Well-Known Member
    Arkansas
    2016 TRD OFFROAD DCSB MGM
    Are tightening it on the ground or in the air?
  6. Apr 27, 2014 at 11:25 AM
    Mitch
    Mitch
    Spokane, WA
    In the air. Light Racing says their is not need to weight the UCA before tightening
  7. Apr 27, 2014 at 3:15 PM
    splitbolt
    Arkansas
  8. May 2, 2014 at 7:26 PM
    Mitch
    Mitch
    Spokane, WA
  9. May 7, 2014 at 12:08 PM
    Mitch
    Mitch
    Spokane, WA
    No more squeak. All the sleeves have been replaced. Found out why the drivers side was squeaking. There was not a speck of grease left on the sleeves or in the bushings. Only on the drivers side. That's why I couldn't move the arms smoothly. Now they have new grease and hopefully a long time of quite operation
  10. May 7, 2014 at 6:33 PM
    ndcmack
    ndcmack Well-Known Member
    NICK
    Western Washington
    BSP 4x4 TRD Sport DCSB
    Not enough
    Sweet. glad to HEAR you figured it out...pun intended:cheers:
  11. May 7, 2014 at 6:41 PM
    wannabetrd
    wannabetrd Well-Known Member
    Zach
    Michigan
    SR5
    3inch front 2inch rear lift with add a leaf and extended brake lines trd exhaust
    I would try to lube the lower ball joint and then tighten the lower control arm cam bolts
