Who has had problems with their 4 wheel drive (electronic transfercase)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JLink, Jun 1, 2011.
  1. Jun 1, 2011 at 7:27 PM
    JLink
    JLink [OP] Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Hey Everyone,
    My truck (2010 trd sport dc lb) is at the dealership for the 3rd time in a little over a month for the same problem. My 4x4 light on my dash blinks all the time and my 4x4 control knob does nothing at all.
    They have (supposedly) replaced the 4wd actuator as well as the front diff actuator.
    They have (supposedly) spent hours on the phone with toyota engineering to try to determine whats wrong with it.
    They have (definitely) pissed me off and made me really doubt the quality of their vehicles, and their work.
    I just want to know who else has had problems with their 4 wheel drive.
    If you have had the same problem as me, great, if something similar please explain. I would just like to have some record of other people with this issue incase they try to say its just me.
    I know there are a growing number of people swapping out their electronic transfer case for an fj cruiser transfercase so they can have manual 4 wheel drive.
    Thanks in advance, I hope I will have some good news soon.
    (and incase anyone tries to say I use 4x4 wrong, I do not. I use it exactly as it explains in the owners manual. I spent alot of money on this truck, I use it in the best way that I can, and I expect it to be able to hold up to the small amount of mild wheeling that I do)
  2. Jun 1, 2011 at 7:50 PM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    i havent yet and really hope that i dont. sometimes it wont come out of 4wheel (meaning hard to get the control back into the 2wheel mode.)
  3. Jun 1, 2011 at 7:52 PM
    Hunter500ky
    Hunter500ky Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
    Sometimes it takes a second,
    I usually shift to neutrual then drive and it kicks in.
  4. Jun 1, 2011 at 8:00 PM
    JLink
    Josh
    Ocean, NJ
    Yea mine just blinks all the time.. I havent had it in 4x4 since after the last time they fixed it, and now its just everyday.. blinks all day.
  5. Jun 1, 2011 at 8:11 PM
    jandrews
    '09 FourDubDee TRD OR
    My T-case front output shaft now makes a small ping when shifting from drive to reverse or vice versa.
    I have determined it to be caused by play somewhere in the shaft assembly, which is taken up in one direction or the other when the gears engage. I haven't cracked it open to determine exactly what the cause is. The truck does seem to have a particularly high amount of slop in the front DS.
    This is possibly a residual effect from when I grenaded my rear diff. It was a particularly bad breakage and may have traveled up the drivetrain and done something to the t-case, such as stretching the chain.
    In any event, it does not negatively affect the truck's performance. I am just very careful about taking up gear lash in the drivetrain with two-foot method before any offroad maneuvers that require significant skinny pedal. I intend to ride the issue like it is until it forces me to fix it.
  6. Jan 30, 2012 at 5:41 PM
    meafordmike
    meafordmike Well-Known Member
    New Brunswick Canada
    08 Tacoma 4X4/ 4Dr 6 speed, Sport/ Towing
    Devil Horns, Wet Okoles, WeatherTechs, Radflo Coilovers, OME Dakar's, FJC Gun metal rims, 265/75/16 BFG All Terrain TA/KO, Rear Diff breather Mod,
    I know this is a fairly old post but to the OP
    I have this same problem!
    The dealer is going to replace the actuator this week, and I hope this helps!! They weren't going to cover it at first (800$ part). But because I have had it in about 10 times over the last 4 years, and after some feet stomping they now will.
    This better fix the problem.
    Check out my thread on this:http://www.tacomaworld.com/forum/2nd-gen-tacomas/30277-4high-4low-lights-flashing.html
  7. Jan 30, 2012 at 5:53 PM
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    I've had two Tacomas with that system and never had that problem. I have a 2012 now and seems fine.
  8. Jan 30, 2012 at 8:06 PM
    TastyHuman
    TastyHuman Oh. Bummer.
    Yep, mine clunks when put into 4wd and half the time won't come out of 4wd until the power is cycled off and back on. A crappy design all around.
  9. Jan 30, 2012 at 8:24 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Mine has worked flawlessly...no problems at all.
  10. Jan 30, 2012 at 8:28 PM
    H Bomb
    H Bomb Well-Known Member
    SAS'd 92 Pickup/08 SR5 Tacoma
    My front diff actuator went out last year. The 4wd light just blinked. It was an easy fix though--cost $375 for a new actuator and took about a half hour to replace!
  11. Jan 30, 2012 at 8:32 PM
    jandrews
    Other item that occurred to me:
    You Jersey boys, from what I've seen in the photos, spend a lot of time dunking your trucks in H20. Never was much for that myself...
  12. Jan 30, 2012 at 8:36 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    I had a problem with mine not shifting into 4lo the dealer replaced the transfer case because some shaft was bent and wouldn't allow 4lo to engage
  13. Jan 30, 2012 at 8:40 PM
    surfrat
    surfrat Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    when my truck was new it was quite difficult to get it in and out of 4wd. Now it seems to work flawless.. but i dread the day and electrical part fails.
  14. Jan 30, 2012 at 8:49 PM
    meafordmike
    I think the high desert has something to do with that. We that live in the salty slushy crap 6 months of the year seem to have this problem more often.
  15. Jan 31, 2012 at 5:09 AM
    JLink
    Josh
    Ocean, NJ
    yea I've decided there is a direct relation between the weather and if my 4wd will work or not.
    Last weekend it was dry, 4wd worked. Weekend before, it was wet and cold, 4wd did not wok.
  16. Jan 31, 2012 at 5:14 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    I've experienced this when it was extremely (sub-zero Fahrenheit) cold. Had to shift into neutral (5spd) then cycle switch 3 times w/ clutch pressed in to get it to disengage back to 2Hi.
  17. Jan 31, 2012 at 5:23 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    no problems here either. or on dad’s 2000 tundra that is push button and has over 200k miles on it. i know we have had the tundra in 4wd for a week or so and never took it out. (to much snow and stuff on the roads in NY when we wear up one time)
  18. Jan 31, 2012 at 7:47 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Mine only blinks for a few seconds when I engage it, I let up on the gas to engage it, and then after it blinks, apply gentle throttle and it kicks in.
    OP it is reasons like this I like the old style 4x4 shifters on the floor, with my 78 Bronco with the hubs turned in, if I put it in four wheel drive, it is in four wheel drive, no screwing around. I think the first generations had those type of 4x4 shifters as weel but am not sure because I have never driven or rode in a first generation.
  19. Jan 31, 2012 at 1:06 PM
    JLink
    Josh
    Ocean, NJ
    Not me.. I avoid puddles when I can.
    But that is what Toyota is claiming. They say I submerged the truck and that the corrosion in the actuators and t case is the problem.
    I grease them all the time. doesn't seem to make a difference. I even cleaned out the t case actuator yellow grease and filled it up with dielectric grease
  20. Feb 1, 2012 at 6:35 AM
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    how often do you guys use the 4wd in your trucks? I use mine pretty much whenever it rains (I know, I know its not for on road, but ive been doing it for 20 years on various trucks and have never had an issue) so its constantly being engaged and disengaged...I've had 3 2nd gen tacos with about 70k miles total between them, never had a problem...maybe you just need to use it more?
