Who has installed an aftermarket exhaust ??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by comicnut25, May 13, 2010.
  1. May 13, 2010 at 7:19 AM
    comicnut25
    comicnut25 [OP] Well-Known Member
    Rob
    Stanwood Wa
    09 TRD 4X4
    So Im ordering a new exhaust for my truck off eBay has anyone installed themselves or should I just take it to the shop?
  2. May 13, 2010 at 7:21 AM
    rjclemen
    rjclemen Well-Known Member
    Riley
    Charlotte, NC
    07 Pre Runner The good looking Blue
    Tint, Bed Cover, HIDs, stubby antenna, double din system, debagded, All Terrain bedside stickers.
    Most systems are just catbacks and can be installed in about 30 mins and you shouldn't even need a jack. Maybe a ratchet some sockets and a flathead to move it around.
  3. May 13, 2010 at 7:23 AM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    I went to a shop for my magnaflow. They let me in the bay to watch them put it on.
    I only paid $35 (shop owner knows me), but it only took him 20 minutes, and that included taking the old exhaust off.
    The stock exhaust is a one-piece, and once you unbolt it in the front you can pry it from the rubbers keeping it hanging under the truck.
    My new exhaust came as a 3 piece. Once they bolted the front part back they hung the back pipe, and used two hose clamps (came with it) to hook both pipes to the what-ever-ya-call-it in the middle. Piece of cake if you have enough clearance to work under your truck.
  4. May 13, 2010 at 7:24 AM
    SCFirefighter
    Stephan
    Cary, NC
    ^^^ What he said
  5. May 13, 2010 at 7:25 AM
    bdwsrjoe
    bdwsrjoe Well-Known Member
    Joe
    Rio Hondo, TX
    08 Tacoma Double Cab TRD Offroad 4X4
    K&N Cold Air Intake, Magnaflow Catback Exhaust, 3" ToyTec Lift Kit, JVC InDash DVD Player with Backup Camera, 2 10" JL Audio Subs, 8K HID Headlights, 8K HID Foglights, N-Fab Nerf Steps, In-Channel Ventvisors, springfield xd40v10, mossberg 500 12ga.
    Install it yourself its very easy.
  6. May 13, 2010 at 7:41 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Install it yourself
  7. May 13, 2010 at 7:45 AM
    jonny
    jonny Betty White Edition Heep ZJ
    did you buy a bolt on cat back exhaust...or just a muffler? muffler-shop to install. C.B.- you can install with basic hand tools :thumbsup:
  8. May 13, 2010 at 8:03 AM
    comicnut25
    Rob
    Stanwood Wa
    09 TRD 4X4
    Sweet sounds easy enough it's a catback exhaust thanks for the quick reply guys!
  9. May 13, 2010 at 8:13 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
    You may need PB Bust if you do it at home. Ramps will make it super easy.
  10. May 19, 2010 at 10:14 PM
    freeskier865
    freeskier865 Well-Known Member
    travis bowdle
    utah
    afe stage 2 cold air,afe catback, 17x9 xd Addict, 285/70/17 Goodyear Duratrac's, toytech 3inch lift kit(5100's all four corners front set at 0 with toytech 3inch coil spring, 2 inch toytec AAL, Spidertraxx 1.25" wheel spacer
    i did it myself just crawled under there with dish soap and sockets and took me 30 mins and was done.
  11. May 19, 2010 at 10:18 PM
    ::childstoy::
    ::childstoy:: Hi-Tech Rednek
    Southeast, PA
    Black 2010 TRD Sport
    TRD Exhaust, Tint, Stubby Ant., Debadged, Weathertech Mats, Grillcraft... Currently collecting donations for a New Tires Fund.
    Whats the deal with warranty if you DIY? Im dead set on doing it and the dealer wants like $200.
  12. May 19, 2010 at 10:46 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    Do it yourself. Installing a cat-back is super easy, a few bolts to remove, some penetrating lube to get the old one off, then just bolt the new cat-back together onto the truck. They usually come in 3 pieces: tube from cat to muffler, the muffler, then the rear portion that goes over the axle and dumps out the side of the truck.
  13. May 19, 2010 at 10:50 PM
    only_K
    only_K 1st Gen. Pride
    Kevin
    Turlock, CA
    99 Tacoma PreRunner
    K&N drop in filter, Magnaflow Exhaust, Billet grille. All 4 Bilstien 5100s. Fronts set at 2.5". Rear 2" AAL.
    I think the better question is "Who HASN'T installed an aftermarket exhaust"
  14. Sep 3, 2010 at 8:11 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    what type of penetrating lube? i know im kinda thread jackin but im in the process and my o2 sensor has 9 years of rust on the bolts and they arent coming off
