who has problems after a 3" or less lift with vsc and who doesn't
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tim allan, Jul 21, 2011.
problems with vsc after lift
Poll closed Sep 19, 2011.
  1. yes
    11 vote(s)
    21.6%
  2. no
    40 vote(s)
    78.4%
  1. Jul 21, 2011 at 5:56 AM
    tim allan
    tim allan [OP] Well-Known Member
    Wv
    2017 double cab trd offroad
    just wondering, thinking about leveling the 09
  2. Jul 21, 2011 at 5:59 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    2007 here... VSC be damned :brianr:
  3. Jul 21, 2011 at 6:22 AM
    tacomik
    tacomik Well-Known Member
    E. kootenays,BC
    11 tacoma TRD
    ARB front bumper,AllPro rear bumper,OME lift,Warn,Lightforce,Weathertech,tint,DSP,piaa,oem roof-rack,canopy,CBI rockrails,Viair
    The anti sway kept activating on sharp corners, removed both ABS fuses and now it behaves properly.( will put them back for winter probably )
  4. Jul 21, 2011 at 6:59 AM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    2007 with 2" lift front & back...never had an issue with the vsc.
  5. Jul 21, 2011 at 7:16 AM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    i have a 3" lift in the front a 2" in the back and i have noticed that the VSC fires off a little more than it did before... maybe like once a month now. it only happens when i make a tight turn and i catch the rear tire on a curb or bounce into a driveway... but its only when making a tight turn.
    so, is it a problem? no.
  6. Jul 21, 2011 at 7:32 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Get the skid control ecu recalibrated after your lift .
  7. Jul 21, 2011 at 8:05 AM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    I'm lifted 2.5" up front and just over 2.5" in the rear and i've never had a problem with VSC. Apparently results may vary. :cool:
  8. Jul 21, 2011 at 9:26 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
  9. Jul 26, 2011 at 7:58 PM
    sdtag
    sdtag Well-Known Member
    So Cal
    2015 TRD Sport DC LB
    lifted 2", snug top, tube steps
    2.25 in the front and 2.50 in the rear and no issues.
    well, the same as before the lift, very rare.
    I'm old now and drive slower.
  10. Jul 27, 2011 at 2:15 AM
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    Mine beeps for a split second once in a blue moon around certain types of turns. Probablly has more to do with me not rotating my tires as often as I should, which reminds me ugh.
  11. Jul 27, 2011 at 3:57 AM
    808hiker
    808hiker Taco addict
    Justin
    Big Island, Hawaii
    I have about 2.5'' of lift and I have never had problems with the system before and after the lift. Then again, I drive the truck gently, if that makes a difference.
  12. Aug 9, 2011 at 5:48 PM
    aGirlandherTaco
    aGirlandherTaco Member
    Katrina
    Oregon
    09 TRD Sport
    KMC XD edition-Enduro Wheels, Cooper Discoverer STT Tires. Westin Bull Bar, Westin Running boards, Billet Grilles, Tinted Windows, 2 inch revtek lift, Under Cover Tonneau Cover
    I have a 2" lift and over sized tires, and am having a problem with my VSC and ABS lights just coming on. I've had my truck for a year, and no problems with either lights coming on. So I took it to les shwab's to get the tires rotated and to have them take a look. and all they did is re-set the lights, not exactly what I had in mind...I'm wondering what could be the problem.
    Also had a new alarm system put in the day before the lights came on, sounds dumb; but could this have had something to do with it?
  13. Aug 9, 2011 at 5:50 PM
    OZ-T
    Peter North
    British Columbia
    Have you had the Skid Control ECU reset after your lift and tires ?
    The timing of the alarm system would make me suspicious , are you having the VSC engage , or are the lights just on ?
  14. Aug 14, 2011 at 8:15 PM
    aGirlandherTaco
    Katrina
    Oregon
    09 TRD Sport
    The lights are on, in the way the check engine light comes on, on the dash....But now those lights (ABS & VSC) have came on and then went off and then came back on again, when I start the truck...they're currently off.
  15. Aug 14, 2011 at 9:10 PM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    My hunch is that if you lose the forward rake it will have more of an effect on the VSC.
    My very non-scientific research (seeing the Tundra fix and reading about who has problems and who doesn't) tells me that a more level or "bro" lean stance will trigger it more easily.
  16. Aug 15, 2011 at 6:21 AM
    YankeePirate
    YankeePirate Well-Known Member
    Lef
    Farmville, VA
    '11 SR5
    3" Lift (Bilstein 5100s, OME 886s, Deaver U402 leaf springs) , KMC 18" Addict wheels, BFG All Terrain T/A Tires, Demello Off-road front and custom rear bumpers, winch, Satoshi Grille. That's it... for now.
    I have a 3" lift and, much like many others here, the VSC will bitch at me briefly when I am going around a sharp turn, especially if I catch a curb, speed bump, or just crappy pavement.
  17. Aug 15, 2011 at 6:22 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    2010, lifted it almost exactly a year and 21xxx miles ago and no problems
    Front:
    icon front coilovers, and diff drop
    Rear:
    walker evans shocks, wheelers aal, all pro u bolt flip kit
  18. Sep 4, 2011 at 7:25 AM
    sdtag
    So Cal
    I just had it happen yesterday. I was getting off the freeway on a sweeping u turn shaped off ramp. There was some gravel in the corner and I was probably braking too hard. I hit the gravel as I was braking and turning and the truck beeped several times real fast for about a second and it did something to the motor, like it killed it or something. after a second the beeping stopped and the motor was fine.
    This seems more dangerous to me than not having this system. I am braking hard in a corner with loose gravel and now I have this beeping and no power to distract my attention from my driving. What were they thinking? How do I bypass this? Did someone say to remove the ABS fuses? I don't like it anymore and I want it gone.
  19. Sep 4, 2011 at 9:01 AM
    85yote09taco
    85yote09taco Well-Known Member
    Eric
    York, PA
    Tacoma TRD OR
    3'' OME lift, TRD CAI, Built Right UCAs, 285 Goodyear DURATRACS, black steelies, Fog light anytime, DTRL, Alternating turn signal, Diff breather relocated, Carrier bearing drop, Weathertechs, Bestop, Extended SS brake lines, CBI Sliders w/kickout, Cab mount chop, Total Chaos LCA skids, All Pro skids, Satoshi(HomerTaco), Bruteforcefab ''HC'' rear bumper, Bruteforce Hybrid front bumper
    I voted yes up top. I only have one turn that I have to be carefull on near my house where the vsc will kick on. That's only when i'm cruising pretty good. other than that i've never had an issue on any other turns.
  20. Sep 4, 2011 at 5:25 PM
    paidfor
    paidfor Well-Known Member
    Austin, TX
    2013 TRD OR 4x4
    Hidden GPS tracking system. Backflip cover, weather techs, bed mat, tailgate lock, OME 885 springs, blistein shocks, 2.5 in AAL/
    09 4x4, 2in life. No problems with VSC
