Who uses top-tier gas that the owner's manual recommends?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Skidog1, Oct 24, 2016.
  1. Oct 24, 2016 at 5:19 AM
    Skidog1
    Skidog1 [OP] Well-Known Member
    Chicagoland
    2016 Black TRD 4x4 Sport DCLB
    I happen to believe the owner's manual and try to use the top tier gas that it recommends. My issue is that I have only seen one station (Costco) that has a top-tier sticker on the pump. The people working at other top-tier stations listed on the top-tier website know nothing about what top tier gas is. You would think they would be bragging about it since it adds cost to the gasoline. Anyway...I use it.
    Kilokato likes this.
  2. Oct 24, 2016 at 5:32 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    I don't go out of my way to look for the top tier thing; it's a gasoline additive package, and your truck won't blow up if you use a different brand.
    I use Costco, Sams, and QuikTrip primarily. I will use RaceTrac or others as needed.
    PvilleJohn likes this.
  3. Oct 24, 2016 at 5:46 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I group this along with nitrogen filled tires. It's a marketing gimmick.
    Tacomas are sold all over the world. Some third world countries have no top tier gas and the trucks run just fine.
    ramonortiz55 likes this.
  4. Oct 24, 2016 at 5:50 AM
    gpb
    Atlanta
    I prefer my tires filled with a nitrogen/oxygen mix at roughly a 78%/21% ratio.
    ebbs15, SpaceTaco, .劉煒 and 9 others like this.
  5. Oct 24, 2016 at 5:52 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    I only fill my tires with unicorn farts. Insist on nothing but the best.
  6. Oct 24, 2016 at 5:55 AM
    gpb
    Atlanta
    Forget that....
    koditten likes this.
  7. Oct 24, 2016 at 6:39 AM
    DanielTaco
    DanielTaco Well-Known Member
    Daniel
    Iceland
    2016 Tacoma DCSB TRD OR 3.5
    I tried a couple of tanks of 91/93 just for the hell of it. Absolutely no difference at all.
  8. Oct 24, 2016 at 6:43 AM
    Biblite
    Biblite Well-Known Member
    David
    2015 F150 XLT SCREW 5.0
    I heard a good batch of shine works pretty well...now that's top of the mountain tier!
    truchador and jmaack like this.
  9. Oct 24, 2016 at 6:44 AM
    PvilleJohn
    PvilleJohn SVT Raptor
    Powdersville SC
    SVT Raptor
    QTFTMFW!
    gpb[QUOTED] likes this.
  10. Oct 24, 2016 at 6:45 AM
    gpb
    Atlanta
    Right, the only difference was your wallet was lighter.
    Using a higher octane than what's needed to prevent knocking/pinging is a waste of money. All the higher octane does is retard detonation in higher compression motors. Zero effect in motors designed to use 87 octane.
    DanielTaco[QUOTED] likes this.
  11. Oct 24, 2016 at 6:55 AM
    gpb
    Atlanta
    Yeah only for the driver though, after it's parked for the night.
    No more than 15% ethanol goes into the truck per the owners manual.
    Biblite[QUOTED] likes this.
  12. Oct 24, 2016 at 7:01 AM
    froejoe
    froejoe Well-Known Member
    Rochester NY
    2016 TRD Sport 4x4 Access Cab
    I try to use top tier gas whenever I can because that's what the manual recommends. When I need fuel but top tier isn't available, I use the "normal" stuff.
    shakerhood likes this.
  13. Oct 24, 2016 at 7:10 AM
    DanielTaco
    Daniel
    Iceland
    When you say "top tier", are you referring to the octane level?
  14. Oct 24, 2016 at 7:13 AM
    froejoe
    Rochester NY
  15. Oct 24, 2016 at 7:23 AM
    Farcedude
    Farcedude Well-Known Member
    Greg
    Westminster, CO
    ‘23 MGM DCSB OR
    Huh, could have sworn King Soopers (Kroger) was on that list, that's where I usually fill up. Guess I'll see what else is convenient.
  16. Oct 24, 2016 at 7:41 AM
    OnceARunner
    OnceARunner War Eagle!
    Georgia
    2016 DCSB TRD Sport Tacoma
    Lots of confusion in this thread. Top Tier is not the same thing as octane level. Top Tier is not a synonym for premium.
    I do 95% of my fill-ups at QuikTrip, mostly because they are by far the best gas station chain I've seen. Consistently clean, fast, have good snacks (freshly cooked), and have excellent employees.
    The fact that their gas is rated top tier is a bonus.
    Kilokato and Aussiek2000 like this.
  17. Oct 24, 2016 at 7:48 AM
    DanielTaco
    Daniel
    Iceland
    I get that now, the list is pretty extensive. I don't see many gas stations that are not a shell, mobile, exxon, BP, 76, citgo, cheveron.....basically all it's saying is don't buy a no name brand gas. That's fairly obvious.
  18. Oct 24, 2016 at 7:58 AM
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
    I agree that the Top Tier marketing gimmick is a rip off for the fuel blenders. However it is pretty clear that the automatic injector cleaning function isn't going to work properly without enough detergents in your gasoline. I usually fill up at a Mobil near my work that is the same price as everywhere else except Costco and Sam's. Perhaps there are some independent labs doing additive tests but since it is the easiest way I just use Gas Buddy to identify top tier stations and fill up there. But I will use a non top tier station in a pinch.
    I use 87 octane as recommended in the owner's manual. I don't think it is worthwhile to use a higher rating.
    Taco16LB likes this.
  19. Oct 24, 2016 at 8:06 AM
    TyFX
    TyFX Well-Known Member
    2016 TRD Sport 4X4 Access Cab - Inferno
    Chevron 87 octane here with no issues.
  20. Oct 24, 2016 at 8:18 AM
    Taco16LB
    Taco16LB Well-Known Member
    Do a little research on Direct injection and top tier gas. You will be using top tier from then on .
    Inferno500 and Aussiek2000 like this.
