Who's doing what for oil pressure and volt gauges ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by beondwacko, Jan 2, 2008.
  1. Jan 2, 2008 at 3:55 AM
    beondwacko
    beondwacko [OP] Well-Known Member
    West Palm Beach, Florida
    08' X-Runner , Sirius radio, fog light mod. Much more to go.
    I wanted to put this out and see what's going on with this idea. I miss the full instrumentation that I had with my old S-10 and honestly speaking, I've always had or installed gauges for whatever vehicle I had. I like to know what's going on with my vehicles.
    I see that there is a supplier for the gauge pod that mounts to the drivers side windshield pillar and I have not heard that best about the fit and finish on those. I'm not against a little bit of cleanup trimming, but rumors of the finish not holding up kinda put me off to those. Not only that but they are also a little bold and can attract attention that I may not want.
    My only other idea was to find some 1.5" gauges to install in the pocket just in front of the shifter. That was my location idea but I also need a little help here for a moment. All of the aftermarket oil pressure gauges that I have installed have been mechanical units. I (this time) don't know if I want to bring in a pressurized oil line into the cab of the truck. So, then I was thinking electric sending unit. Where in the hell do I find a pick up point on the 4.0L ? Also, what is the correct thread for adapters?
    Post up guys and girls. Pics would be a bonus too!
  2. Jan 2, 2008 at 6:54 AM
    Don G
    Don G Old Goat
    Southern Tier New York
    "08" Tacoma Access Cab TRD Sport 4X4
    Hey wacko! !! I don't have an answer about where to get the gauges but I do agree that I think they could have done a better in the design of the instrument panel! !! ! I believe Toyota should let Truck people design Trucks:D
    HAPPY NEW YEAR
    Don G
  3. Jan 2, 2008 at 7:04 AM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    Here is the Lotek Pod everyone is talking about. I didnt have any issues with the finish and I was pretty rough putting it in. I had to trim the handle a little to get it to sit flush but that was about it.
    now, I do know that they make an adapter that will fit between the oil filter and the motor and give you two pickups for oil pressure and temperature. I run fuel pressure so i dont personally use it
    Here is the place that makes them
    http://www.striracing-usa.com/pro_a.htm
    oil block adapters
  4. Jan 2, 2008 at 9:10 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    I use my scangauge for measuring volts, water temp and intake temp. Don't bother with oil temp or pressure beyond the stock display.
  5. Jan 2, 2008 at 11:36 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    That's something Scangauge could probably do in the future.... If we all pushed it hard enough. I'm still waiting for the Transmission temps to be available.
  6. Jan 2, 2008 at 5:28 PM
    My68ur8trd
    Justin
    Williamsburg, VA
    yeah, the scan gauge is sweet :D
    Justin
  7. Jan 7, 2008 at 9:09 AM
    SteelCity
    SteelCity Wherever I May Roam
    Charleston, SC
    06 Radiant Rd DC LB PreRunner SR5 V6
    Optima Red/Stinger Terms, DT Headers, Empire O2 sim, Bluetooth, USASpec PA12TOY, Redline Struts, Extang Tonneu, OEM Bed Mat/front Skid/Roof Rack, Grillcraft Grille, Susp TSB, Toytec 1/2" front spacers, Raammat/Ensolite, Sony GTs, Curt Hitch, Tranny cooler, Wet Okoles, AFE Pro-Dry Drop in, Muth Sig Mirrors, Temp/Comp RVM, Silverstar HLs/Fogs, Royal Purple Diff/PS Fluid, Detroit Truetrac LSD, Hellwig rear sway bar, SG II, Filter Mag, 265/75/16 Nitto TGs
    ........but where do you get the pod?
  8. Jan 7, 2008 at 4:00 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    I bought a Toyota so I didn`t have to worry about it.
  9. Jan 7, 2008 at 5:09 PM
    sako243
    sako243 Active Member
    pennsylvaina
    2008 taco 4x4 off road v6
    scangaugell, bug deflector,
    i bought a 08 acc cab 4x4 with the v6 just ordered the scan gauage and the tech told me there working on the trans temp and when it comes avabile the will put it up on the web site
  10. Jan 7, 2008 at 7:40 PM
    My68ur8trd
    Justin
    Williamsburg, VA
  11. Jan 7, 2008 at 8:27 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    my volts come from my headunit. i can can show volts, speedo, compass, incline, and a few other things
  12. Jan 8, 2008 at 12:21 PM
    SteelCity
    Charleston, SC
  13. Jan 9, 2008 at 4:52 AM
    danusa
    danusa Well-Known Member
    What is to scan?
    No oil pressure? Idiot light.
    I too want gauges.
    We have abdicated to what to control our fate?
    Ampmeter showing discharge? You might want to look into that.
  14. Jan 9, 2008 at 5:49 AM
    My68ur8trd
    Justin
    Williamsburg, VA
    The idiot light it too late and the damage could be done,
    I like Oil pressure, Fuel pressure, and if you have an auto ( especially with lift, tires and s/c) Trans temp
    Fuel pressure worked for me cuz at Redline I can see the pump give out and fuel pressure drop, which is why it leans out a bit
    Justin
  15. Jan 9, 2008 at 6:55 AM
    danusa
    Gauges were not a problem in the old days. Just cut a hole and run the wires.
    Try that today.
    At least, they can give us an oil pressure gauge that you can read in PSI. And not have to hang off the steering coloum. How tacky.
  16. Jan 9, 2008 at 7:30 AM
    rhoppas
    rhoppas Land of Oz
    Topeka, KS
    07 Double Cab V6 TRD Sport Tow
    Earnhardt Cannons, Terra Grapplers, Viper alarm, Hunter4x4 Bull Bar, 6" Pro Comp Off-Road lights, extra set of bed D-rings, Chrome exhaust tip, Metra Ipod/MP3 adapter, Garmin GPS, CarriageWorks grill, Maglite mounted to driver seat, 9" Stubbie Antenna, WeatherTech floor liners, Saddleman Neoprene seat covers, DeeZee bed mat
    I agree Dan. The ScanGauge is cool but I wish someone would come up with a less tacky method for mounting it in the taco. That is the only reason I haven't purchased one yet.
  17. Jan 9, 2008 at 7:32 AM
    rhoppas
    rhoppas Land of Oz
    Topeka, KS
    I REALLY like the looks of the pillar pod but by the time you buy the pod and a couple gauges you could have bought a ScanGauge. And the ScanGauge does so much more...
  18. Jan 9, 2008 at 8:18 AM
    danusa
    You do an instrumemt and mirror scan every 30" just like you were taught right?
    This idea, not only does not give you the information, it is un natural.
    I should say that I am a pilot and used to instrumentation being where I see the really important things first. I have to lean over to see the EGT. But if I`m in trouble, which would be close to the ground, I have it full rich anyway. So the EGT is a nice gauge to lean the F/A Mix with at altitude.
    eg: If oil pressure needle does not move I shut down the engine until I know why.
    This only makes sense.
    The compass on the taco has saved me a wrong turn. I have one on the `62 GMC. It is a wet not digital, yet it tells you the same thing more exactly.
  19. Jan 9, 2008 at 3:34 PM
    My68ur8trd
    Justin
    Williamsburg, VA
    scangauges doenst show oil pressure, or fuel pressure, or EGT. Our trucks dont even monitor fuel pressure
    it does show water temp, intake temp, volts, and the other OBDII parameters.
    putting it on top of the steering wheel actually doesnt look that bad in person. It was the only place to put it a make it easy to see. I use it to watch the switch from closed loop to open loop when tuning.
    for me it was as easy as running the wires and the boost line to the engine bay and being done with it. The URD S/C has an additional fuel like going to the 7th injector which you just unscrew and put the fuel tap inline. super easy
    Justin
  20. Jan 9, 2008 at 5:34 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
